hey guys, its an rb26/30, xtr manifold from gcg, t04z turbo, exaust housing was supplied by gcg, the thing doesnt seat on the manifold properly and the compressor housing fouls on the side of the engine bay, doesnt matter which way i twist it it hits the casing for the captive nut that the top camber arm bolts through.
gotta wait till tonight to load photoshop and shrink the pics so i can upload them
https://www.sau.com.au/forums/topic/316151-bad-turbo-fitment/
yeh ill give them a call on monday, but obviously they are not open today :blink: the rb30 30mm taller as you know so mayby it doesnt account for that as it was for an rb26, the exaust housing is a .82 so its not the big one. ill give my exaust place a call to see if they can cut and weld the flange at a different angle, the space between the housing and the valve covers is huge. i bought the manifold of gcg over a year ago so they'll prob just tell me to buy another manifold.
Edited by s13_Skyline_inside
Well something to note is that a T04Z is a T4 P trim based turbo meaning it uses a T4 turbine housing and not a Garrett GT30 based one like GT30 and GT35 BB turbos are supposed to have .
The manifold may have been designed for a GT BB turbo , anyway ask GCG because they should know .
A .
something tells me that turbo and manifold werent a paired combo on production...
cant honestly think of an economical way to fix that other than to swap the manifold or turbo for an alternate option (resell rebuy)
What does 30mm of the block have to do with it?
The head doesn't change position in any other way than upwards.
It's 38mm and it doesnt just push the head straight up, our engines are inclined towards the passenger side of the car so it pushes the head laterally somewhat too.
I had a similar issue with the 6boost manifold and GT35R on my 25/30, had to send it back to Kyle and he moved the turbo flange forward 25mm, that combined with slotting the drivers side engine mount (to tilt the engine up a few degrees) got the turbo to fit.
do you think it would be an option to get an exaust place to cut and re weld the manifold?
it is an option, however i would consider it a less economical option based on product quality.
personally i would want to have a new manifold made as if you think about it, a slight change will require quite abit of work. shortening or repositioning any of the runners of collector will change the angle at which the pipes need to run at the moment meaning the changes will be fairly major. essentially meaning time consuming and tedious, which results in costly and CAN result in a poorer quality item.
if you arent too concerned about quality etc and just want it on, you can try find somewhere to do it for cheap. otherwise id resell and start over, hope that helps.
makes two of us then, well anyway went to see the guys at castle hill exaust today with pics and they dont think it'll be an issue, the manifold can have the flange cut of and welded on at a different angle, ill chuck some pics up in a few weeks after i get the work done
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
