Hey people my passenger side headlight seems to come on sometimes then other times wont if i play with the wire on the terminal it comes on then fine, but i dont understand why its not staying on, can any 1 shine some light on my issue.
https://www.sau.com.au/forums/topic/316155-headlight-issue/
My R32 has a similar problem. I believe that it is a problem with the switch assembly, a real bugger to fix apparently.
https://www.sau.com.au/forums/topic/316155-headlight-issue/#findComment-5184969
Not sure if its the exact same problem, but i had a similar issue with my high beams in my 180sx.
found the problem was in the control stalk box part.
either way, i made a write up on how to fix that, not sure if it is exactly what you need, but it might help.
This is the write up
or go to http://vidmes.com/c/ for a brief run down on what it is.
https://www.sau.com.au/forums/topic/316155-headlight-issue/#findComment-5185016
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
