Question...
After putting on my new front mount kit I have realised that the old piping had a nipple on the cold side of the piping just before it turns 90deg toward the throttle body, to which a vacuum hose from the power steering pump is connected... The new piping does not have this.... :blink: do i need to re route this? or have a nipple put on the new piping?
https://www.sau.com.au/forums/topic/316165-intercooler-piping-question/
Question...
After putting on my new front mount kit I have realised that the old piping had a nipple on the cold side of the piping just before it turns 90deg toward the throttle body, to which a vacuum hose from the power steering pump is connected... The new piping does not have this.... :P do i need to re route this? or have a nipple put on the new piping?
Ah, that's not gonna be going ot the power steering... it'll be for your boost controller I'm guessing.
If you don't connect it, chances are you'll get infinite boost.
I'd be putting a nipple on the new piping ASAP.
blocked mine off 3 years ago and never had an issue mind you im now running a greddy boostcontroller .and i was told it was power steer too.as i said never had an issue with it
i know the one you mean, and it does go to the power steering pump as you said. i'm not sure what the pump does with it though, but it wouldn't be a vent if its going back into i/c pipes. maybe some kind of vacuum/pressure assist for the pump? i'd hook it back up with the wastegate/boost controller line.
hi there mate...
what ive done is for my controller taken a reading off the waste gate and then the plenum... this is goingto give you a more accurate reading as its litteraly just as it passes into the engine...
and its on the same pipe just after the throttle body
EVERY thhing eles needs to be blocked off...
what boost controller u running??
on my last s2 i had a nipple put in but the way ive said above is the same in theory.
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
