Time to sell my 1994 skyline r32 GTR.
It's a sliver on the out side and gray on the inside. it has 154000 on the clock and i am after around 23 but make me and offer.
I have put a new wolf 3d v500 computer in it.
New brake pads and disc's all round.
New front upper control arms.
New bosh fuel pump one way speed flow valve speedflow -6 90deg
clutch kit
rear main oil seal
all the belts are new
just put new tires all round
just had a major service
changed both engine mounts
drive shaft
all this was done so there would be no problems. car also have a alpine dvd player in it.
if you would like to have a look at the car call me any time on 0433031074 and ask for shannon the prices is neg need it gone asap
https://www.sau.com.au/forums/topic/316170-r32-gtr-forsale/
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
