Put some black silicon on the thread.
^^^ This.
That's an odd place to leak, and I doubt you'd have much air leaking from there anyway.
You wouldn't even be able to measure a leak that small, let alone notice a difference in power :D
look for more leaks in cooler piping etc......
Oh an BTW, that wont damage your turbo at all if left, but take the comp housing off and fix it anyway...
If ur leaking from there im pritty sure uve got a bodgy O ring install prolly got jammed when the core was put in ... ive seen it done b4 but i spotted it b4 it was installed so we fixed it up but yeh man maby the O ring is damaged...?
found most of my leak from the cooler piping hoses when i did the boost leak test.. tightened the clamps and no more leak.
only from the bolts that i showed in the pic.
i tightened all 3 top bolts but the bottom bolt (in the pic ) still leaks.
will do the test again since i only did the test at 5 psi ( maybe try 7) which took a while to hit
the car feel abit better then before but the power feel linear compare to the stock turbo. (im guessing there still a leak somewhere)
i'm running stock actuator with the solenoid removed 5 psi( have a hks adjustable actuator as well)
stock airbox with apexi panel filter
full exhaust
return flow front mount
safc2 not tuned
z32
gtr34 pump
my plans where to find all leaks and get it tuned with the safc2 (for now) and save funds for injectors and a nistune
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
