R32 Gts-t Sedan
I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
So, what did you decide? If these items were going in and out of stock, you could at least order the two in-stock pieces. Also, I'd say the stock bit of airbox isn't that restrictive to your NA motor. To test if it is, fit a vacuum gauge between the airbox and throttle body. At WOT do you measure any vacuum?
