Hey all sorry if it's a noob ? And been asked 100000991 times but I'm curious as to how much boost you can run with standard internals ? Would 18psi be alright I've been told you can run upto 20psi but just wanna make sure . Standard internals on a R32 GTR .
Thanks everyone and sorry if it's a repeat thought I'd ask the profssionals !
You're basically asking "how long is a piece of string"
I wouldn't run anymore than 12psi from a standard turbo
10psi on a standard turbo and ECU
20psi on a Garrett GT3076 with water meth
16psi on a Garrett GT3076 without water meth
32.4 psi with a T88
No I won't be running standard turbos . Was maybe going either gt3040 or something . My mate has one on his 25. Just want it to punch in then to haul . Just wondering what the motor itself can do without doing alot of collateral damage .
The question is not how much boost can you run. The question is at what power will the motor start to lose reliability.
Just go for 300awkw and keep everything safe. If it's stock now, 300awkw will feel like a totally new car, and it will be a lot of fun and given your extra grip should be well infront of your mate
Haha yea I only intend to give it " weeties " . Basically I like the way it pulls wen it hits boost . Not really after a big power figure or a dyno superstar I might add also . Just after the pull it gives on boost . Might sound abit weird or crap but yea just like to put the foot down and wind it up. But 300kw would be nice !
my 32 R got Nismo turbos, EBC set for 19psi, gets around 20.5psi on cold nights, Unopened engine, all the supporting mods, bar injectors, had no probs, i drive it on 16psi most of the time, and only 16psi on the track.
Also depends on the motor, how old it is etc
If its a R32 RB26, you are looking @ 15-20 years old, i wouldn't be putting 300rwkw through it personally if i couldn't afford the rebuild. They are getting extremely old now.
I'd stick to 280rwkw, 16psi or so and make sure it's well serviced in the above scenario.
Golden rule with stock RB's, if you cannot afford the rebuild, then don't go chasing even 'reasonable' power.
Thanks for the info deano . Yep hence why I'm not chasing power figure . Just the pull and boost but not more then 18 full is what I'm hoping . It's got 106xx and i'm servicing it regularly as I need to .
What part of the engine is getting old? I know the metal will be getting slightly more brittle especially the head, but is the main area of concern the pistons gaskets and rings? I'm guessing there isn't much else to be replaced (cams?), but is that the crux of it?
Also, what sort of power for a R25? I'm guessing the 280kw is more like 260 or so?
yer my car made, 312awkw, on 19psi, i service my car alot, the oil has never been in teh engine for longer than 3000k since ive owned it, and my cars only got 70klm on it, and it has been looked atfer all its life, it also only gets drivin prob twice a month, i always use top shelf oils, and its a really safe tune, see how it gose after a trackday this weekend : D
How much risk are you willing to accept? Basically, more power = more risk of the engine blowing up. Nismoid's suggestion of ~280kw is very safe provided you're changed the turbos, and probably means you can still use the standard injectors and AFMs. IMO 300kw is still very safe on a motor that's running well, and that's where i've stopped. 280-300 is whole new ball game compared to a 175kw stocker.
I have been running 20psi for about a year, and the back turbo has just let go, (most of the turbine is in the Cat..) and it would appear they were actually stock ceramic turbos... (Was running 20psi when it came from Jap, so figured they had to be steel) but it does seem that 20psi is a lot for standard motor, will be aiming to run less with the new turbos
just got mine tuned yesterday on 1.2 bar stock motor unopened but with steel wheel N1 turbo's. made 274 kw and on 1 bar made 256kw
was tuned with power FC
plenty of safe power for a stock 1990 GTR
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
