I have a r33 rb25det. I recently blew the turbo and replaced it with a high flowed and rebuilt rb25det turbo. Now the car is idling between 1200-1500rpm at all times. it Doesnt change whether its cold or hot and i have checked all vacuum lines, every gasket on the intake side of the engine, basically everything. I have since put my stock BOV back on and besides the front mount intercooler kit, pod filter and exhaust the car is stock.
As for boost control i am using just a vacuum line from the intake manifold to the turbo actuator.
Ive run out of ideas as to what it may be so any help would be greatly appreciated.
Thank you :P
Edited by tom_v
https://www.sau.com.au/forums/topic/316232-high-idle-problem/
Just found the DIY for "Aac Valve Cleaning & Idle Reset"
http://www.skylinesaustralia.com/forums/Di...nd-t110431.html
Ill give this a try and see how i go, i really wish it didnt get dark so early now, bring back day light savings! lol
I just finished cleaning out the AAC valve. I Disconnected the TPS and let the car idle. It sat at about 1200rpm as it previously was. i then turned the adjusting screw on the AAC valve to lower the idle. i got to about 950rpm when the screw was fully in. Im guessing it is still not right cause it should not be all the way in. Should i adjust it now on the ecu??
Also there are two plugs on the TPS, i did the adjustment with the grey top plug disconnected as when i disconnected the redy/brown plug it just reved very high. Was this correct???
Edited by tom_v
Ill check that its bled properly, it probably isnt, but would that really make it idle all the time at 1200rpm? Like even when its cold and first starts up?
the idle control valve has water running through it, air lock will cause it to do weird things.... S15's are the worst for it as the water runs through the TB... they will idle around 2500rpm if airlocked :D
Ive checked the cooling system, its all bled up fine. Im wondering if because its a high flowed turbo it may be pumping in more air then a standard and rasing the idle. Has anyone put a high flow on and experienced something like this?
Ive adjusted the idle by clamping off the pipe to the AAC valve and setting the base idle by adjusting the little screw on the throttle. I did this with the TPS disconnected then after setting it all, reconnected the TPS and switched the car on and off. It now idles at 900rpm nicely and the AAC valve adjusting screw is not all the way in... Is this ok? Ive listened and checked all vacuum lines, even checked by spraying brake cleaner over every line and did not get any reaction from the engines.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
