I have a r33 rb25det. I recently blew the turbo and replaced it with a high flowed and rebuilt rb25det turbo. Now the car is idling between 1200-1500rpm at all times. it Doesnt change whether its cold or hot and i have checked all vacuum lines, every gasket on the intake side of the engine, basically everything. I have since put my stock BOV back on and besides the front mount intercooler kit, pod filter and exhaust the car is stock.
As for boost control i am using just a vacuum line from the intake manifold to the turbo actuator.
Ive run out of ideas as to what it may be so any help would be greatly appreciated.
Thank you :P
Edited by tom_v
https://www.sau.com.au/forums/topic/316232-high-idle-problem/
Just found the DIY for "Aac Valve Cleaning & Idle Reset"
http://www.skylinesaustralia.com/forums/Di...nd-t110431.html
Ill give this a try and see how i go, i really wish it didnt get dark so early now, bring back day light savings! lol
I just finished cleaning out the AAC valve. I Disconnected the TPS and let the car idle. It sat at about 1200rpm as it previously was. i then turned the adjusting screw on the AAC valve to lower the idle. i got to about 950rpm when the screw was fully in. Im guessing it is still not right cause it should not be all the way in. Should i adjust it now on the ecu??
Also there are two plugs on the TPS, i did the adjustment with the grey top plug disconnected as when i disconnected the redy/brown plug it just reved very high. Was this correct???
Edited by tom_v
Ill check that its bled properly, it probably isnt, but would that really make it idle all the time at 1200rpm? Like even when its cold and first starts up?
the idle control valve has water running through it, air lock will cause it to do weird things.... S15's are the worst for it as the water runs through the TB... they will idle around 2500rpm if airlocked :D
Ive checked the cooling system, its all bled up fine. Im wondering if because its a high flowed turbo it may be pumping in more air then a standard and rasing the idle. Has anyone put a high flow on and experienced something like this?
Ive adjusted the idle by clamping off the pipe to the AAC valve and setting the base idle by adjusting the little screw on the throttle. I did this with the TPS disconnected then after setting it all, reconnected the TPS and switched the car on and off. It now idles at 900rpm nicely and the AAC valve adjusting screw is not all the way in... Is this ok? Ive listened and checked all vacuum lines, even checked by spraying brake cleaner over every line and did not get any reaction from the engines.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
