  • Replies 66
considering how far is shunted the other cars, its actually held up real well.
dont care if people show off, but i would still laugh/taunt this guy, ferrari drivers shit me... "hey buddy, that parkin' spot's already occupied!"
He's going to be farking sore in the neck tomorrow. He obviously hit something right at his door which would have wrenched his neck big time.
Never tried to drive really hard and/or show off in a mid-mounted engine car but im sure once the start spinning up its really easy for them to get well out of shape
(doesnt detract from the fact the guy is a douche for crashing, and doing it in a busy area with kids etc around).
good work on the pics and vid for our entertainment:p
http://aussieexotics.com/forum/ferrari/fer...rs-t6967.0.html
Heres the link.
FYI the cars not that expensive, a new R35 gtr is easily worth more than this, also a 2nd hand auction job import R35 is still worth more. Looks like a 97 model F355
look on the bright side at least it wasn't a skyline crashing ( i swear as soon as a cop see's one of these in a accident its automatically decided he's guilty and to bring out the taser )
in hindsight seeing an R33 rear ending someone isnt a uncommon sight, have to chuckle sometimes..
Heres the link.
F355 is about mid-late 90s is it not. that means it would be a $150k car if you were lucky.
still not a cheap thing to smack around but they still do..
I know a guy here in brissy that has one as a toy and his shitbox daily is a 308.. go figure
How many other owners of that model there (if any) do you reckon had greedy thoughts about their now even rarer car going up in value?
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
