Theres a few big name aftermarket jobbies around, mines, HKS, Tomei and the price can vary a fair bit !
is there one particular brand that is considered better than any others ? (doesnt have to be jap)
it probably wouldnt be a problem on a low power car, but looking in the vicinity of 400-450rwhp every bit of flow would help (HKS GT-SS or 2860-9's)
cheers
https://www.sau.com.au/forums/topic/316283-best-dumpfront-pipes-for-a-26/
  • Replies 96
Cheers for reply :D I figured they'd be adequate for th power level. Same ad turbo manifolds. But in the chase for ultimate response would bigger be better ?
Also does ceramic coating and heat wrapping give enough benefit to bother with it ?
I made some good gains in response and power using the trust dump pipe kit.
Definatly ceramic coat the ex- housings, dumps and Y pipe. Also look at a heat shield on the front dump pipe, to keep as much heat away from the rear air intake.
Cheers
Justin
http://images.google.com.au/imgres?imgurl=...3OY3s7APwzenwCQ
^^^^^ hands down the best fullstop.
Best factory setup is the R34 gtr getup.
cheers mate ! looks like a nice piece of kit, any insight on weather an aftermarket ex mani is worth it ? again purely for MAX RESPONSE, i know the stock item is said to be adequate for fairly high power levels, but im chasing every bit of response i can
cf drive shaft
lightened flywheel
aluminium pulleys
anything i can think of to get nice early spool so even if mani/dumps dont get more KW its not an issue
As i said above - i swapped out dumps FROM aftermarket back to stock - there was no response difference to speak of.
just dumps or full front pipes ?
I know the dumps are cast pieces but if the stock front pipes on a 26(34 Vspec II if it makes a diff to zorst) looks anything like the pressed items on my old 32 (rb20) then id want to swap them pretty quick
R32 or R33, can't remember exactly :action-smiley-069: They aren't R34 items thats for sure.
280rwkw @ just over 1bar (i think around 15-16psi) on GT-SS's.
There is a another car i know of, exactly the same setup as mine, with a smaller exhaust - 330rwkw @ 20-22psi, factory dumps as well.
That's how we came to give it a go on my car, given this car was restricted to factory dumps for some sort of class racing i was told.
I'm yet to enquire if there are anymore setups that have since followed suit so i won't speculate.
If i ever get off my ass and finish off everything, i'll end up @ the same... I'm lazy :wub:
Nah not factory front pipes, aftermarket. JUST the Dumps im talking about.
The front pipes i have are 2.25" x2 (im pretty sure) into a merge with a 3.5" from there back.
cheers for the info, very knowledgeable as usual :action-smiley-069:
C.E.S here in Brisbane make a setup like the greddy setup, in stainless and mild steel, 3 inch or 3.5 inch, I run the 3.5 inch setup on my race car, I got them ceramic coated and they are surprisingly light for the size.
What kind of price are you looking at for those?
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
