  • Replies 96
That CES stuff looks pretty nice! Although they have TERRIBLE customer service. Everytime I contacted them for pricing and delivery eta etc they couldnt tell me or the person who knew wasnt there and they never ever called back! Nor did they reply to emails!
But anyway I had the HKS dumps with -5s and with my ultra high-flowing exhaust, i had serious boost creep. Creep from 18 to 22+, it was uncontrollable.
I then went to R34 Stainless factory dumps and the problem was ALL GONE.
I say bolt on a pair of 33 or 34 factory dumps, and get a nice front pipe. Just as long as the inlets to the front pipe are the same size as the outlet of the dumps (no need to get any bigger) youll be fine.
Oh and dont forget adjustable cam gears for awesome increases in response :D
Im putting together a front set to match the 3.5" 5Zigen cat-back on my track rb26
* twin equal length tubular manifold
* twin hks split dump pipes
* 2.5" dual into 3.5" single front pipe
highflowed turbo's.
eventually doing a big engine build. got 90% of parts now :D
So what this says to me is the stock bumps choke an exhaust....
When we're talking ceramic coating of all the hot bits, what sort of gains are we talking 5 , 10 hp ?
naa man its more complicated than that.. stock exhaust parts are generally ok but stainless heats up your engien bay like a mofo
and a lot of GTR's just have open pods in their engine bay, so all that heat in the bay is making your air coming in hot
its basically driving in winter vs driving in summer
I was trying to locate a pair of R34GTR dumpies for my -5's but had no luck. Was about to go the Tomei route then got lucky and bought the CES race pipe system second hand for less than the price of tomei's! (and it was already ceramic coating)!
But for cost effective and good enough response R34GTR dumps are meant to be good and very cheap to buy (but they sell very quickly:)
So NO retuning was done at all? Got graphs? Power was identical was it? Personally I find this very hard to believe, im sure im not alone...
Nothing was changed, just the dumps.
No graphs of the before, i already knew what power it was making and it was identical to the after.
I know the car very well and i could feel there was no difference in boost ramp up/response.
Are you hard of reading trying to deliverately turn this into the same as the last thread where you were wrong and then tried to backpedal out of your own statements?
I told you the power output was identical.
What i was referring to was boost response on the street, no change.
@ 3,300rpm the boost gauge did the same show it always does. Identical before/after the dump swap.
Peak boost/power (via dyno) was also the same.
Im not backpedalling, just questioning the sh1t you post as fact when its not always the case...youre previous statement about air temps not being as important as fuel/ignition was wrong, get over it.
I would put my house on the fact that your experience with dump pipes is not the norm and that 99% of the time people will make gains from aftermarket dump pipes...maybe you scored some 'freak' dump pipes.
Youre as good as alleging the manufacturers of a/m dumps are lying when they back to back test their product and show gains? Is that what youre suggesting, indirectly?
You did. Still obviously unable to accept you were wrong either. This is even after others pulled you up on it... ;) meh.
There are 3 cars i know (after asking around) including my own running R33/R32 dumps, 330rwkw/-9s etc etc. FACT.
These setups are the same as other setups WITH bigger dumps (all from the same workshop, same build specs etc). FACT
There are another 5-10 cars running upto 400rwkw with R34 items, and dozens with aftermarket ones - again identical. FACT
Now fair enough there is some minor variance, every motor is not 100% identical, however when the results are all similar enough that there is no signifigant difference...
Good enough proof for me, and i am one not easily convinced.
Hell there could even be more now as I've seen a fair few people jumping on factory dump pipes when they come up in the For Sale area.
Notice the word FACT there? It is the case. It is as real as the very keyboard you type with.
I'll tell you what i'll do. On Friday I promise i will try to get a part number off Nissan for these 'freak' OEM dumps when I'm down there.
I mean they must exist if there are countless results to back them in your eyes.
What i can't promise though, is my very resourceful parts contact, looking at me with a straight face...
So in your absolutely ridiculously over exaggerated examples above, these 'DOZENS' of cars are running identical boost, ignition maps, cam timing, fuel mixtures...cmon man, get your hand off it ffs...
No 2 cars are the same, agreed, the basic principles remain the same regardless...more air/fuel in, more exhaust out as quickly as possible...
I would like to see a comparison of exhaust temps after repeated thrashing....youre one off dyno reading is fine as long as thats all youre doing in the real world I guess, an occassional 4th gear pull?
When I looked at Xforce they had a all in one kit that was turbo back, that would include the dump and front, but I'm not sure in this case they are different physical pipes?
Xforce... kthnxbai
Oh and dont forget adjustable cam gears for awesome increases in response ;)
sweet, cheers for the advice ! ;)
wtf do exhaust temps have to do with anything?
All X-force stuff is, is the same china crap you buy from ebay but with a bigger price tag and a X-force badge welded to it
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
