Hello boys, i have finally saved the money for a R33 GTR.
So i would just like to ask someone who owns or has previously owned an R33 GTR, and that could tell me what i should know when buying and when owning one, such as costs of maintaining it etc etc?
The GTR i get, ill be pumping it to 270-300KWs so it will have just light mods, exhaust and boost, keeping it street legal so police cant defect me.
https://www.sau.com.au/forums/topic/316301-owning-a-r33-gtr/
Well first off, you won't make 300RWKW with just light mods, although given you have money for a GTR perhaps they would be classed as light money wise :D
The GTR only really differs in the engine compartment, most of the rest of it uses similar/same specced parts (read: same price to fix when broken), so it is really only the engine bay you have to worry about.
I've never owned, but considering the high similarity for engine components there shouldn't be much difference to a 33GTST or 32/34GTR for that matter.
Basically, you can abuse the engine and other parts more, but they will be 20-50% more expensive to fix if you break, mostly in parts cost, somewhat in labor (RB26DETT is a bit more time consuming to work with, dual turbos etc).
the whole drivetrain is different and so are the brakes and panels. getting it serviced will cost more than a gts-t, also tyres will be more expensive because they run fatter rubber. in my opinion everything about a gtr is more expensive than a gt-t or gts-t. forgot to add r33 and r33 gtr has the same gearbox but the r34 gtr is different.
Million dollar question... If you found something thats in very good condition, why would you be spending more? If something did break, of course it'll be more exp than a single turbo car. This applies to any twins. I dont have any issue with my 33gtr at all since buying it 1 year ago and running 250awkw now. You wouldnt be pushing 300awkw with stock gtr turbos at all. You'll be looking at 250awkw.
As BNCR33 said, changing turbos is an expensive process. GT-SS will be around 3.5k, dumps will be 500 and labour will be easily 1k. Thats 5k all up excluding your ecu, boost controller etc...
Maintenance wise it'll be the same as any other AWD cars if its mechanically A1.
300kw is piss easy in a gtr, as you say light mods.
I spend about $8K a year on mine all up (incl rego, insurance, fuel and everything else), but i'm always doing extra stuff to it. This year will be more like $12k due to turbo replacement...
My recipe for 300kw is;
Less than $2.6K for turbos (2860-7s)
$500 for seimens injectors
$400 for Nistune
$340 for modified xforce dumps (car already had dump back)
$850 for CRD tune (other places would be less)
Around $1K for labour
I'd do the turbos (and dumps if ever going to do them) straight away after getting the car. All the other stuff can wait.
I dont call fitting new turbo's light mods. To the OP, if you buy a GTR that is in good cond it wont cost you very much at all weekly wise. I budget $150 a week . That inc everything. And its my daily ride too. Look after it and it will look after you.
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
