as the title shows my outer tie rod ends are worn so im looking at replacements.
Oem nissan ones are expensive like $200 for the pair.
Did some searching and found that part number pte 926-14 is the aftermarket type which pedders have for $70 a pair and bursons have them in stock for $55 a pair,
before i buy them i rang a reputatble suspension joint who advised he didnt think they would be the right part and advised they have a more expensive item in stock.......
now the part number PTE 926-14 comes up on pedders online as for the r34 gtt , its also the same part number for r33 gtst howver r33 have three different options depending on there series...
Can Anybody clarify if the part will fit a r34 gtt???
https://www.sau.com.au/forums/topic/316308-r34-gtt-outer-tie-rod-ends/
  • 1 month later...
i can confirm went ahead and bought these , i just installed these they are exact specs as oem and are only $27 each!.....
I just purchased a pair from TuneAgent for $130.00 for my GTT, I hope these fit!
Once installed, did you notice a considerable difference in the front steering and wobble felt through the steering wheel?
  • 2 years later...
  • 1 year later...
Just to add to this thread. (Hope you all find this useful)
Recently changed my outer tie rod ends on my R34 RWD.
You can use the Honda outer tie rod end part number "53540-SK3-E01". Exact same as PTE926-14.
Don't get ripped off by some sellers claiming that the outer tie rod ends for RWD R34 are exclusive.
The same outer tie rod end will also fit N15 pulsars and A32/33 Maxima (possibly other Nissan models too). It will also fit Rover and some Volvo models too.
Cost me $48.00AUD from eBay. (July 2014)
  • 2 years later...
Thank you this thread was very useful.
I do have a few questions; are the tie rods the same for all four wheels?
And would tie rods from Nissan 300xz 91-95 fit the gtt?
Edited by Spitz
Typo
  • 4 weeks later...
Thread resurrect.
I just got some Transteering TE-926-14 (101mm, made in Taiwan) tie rod ends for my R34 GTT steering rack (front).
Looks like these come with grease nipples, whereas the OEM's are sealed I'm pretty sure.
What's the correct procedure to grease these and what grease should I use?
Thanks guys.
  • 2 months later...
Thread bump anyone know the r34 rear outer tie rod end part number or where to get em? Bursons only have fronts
You may find it easier just to eliminate Hicas completely: https://www.ebay.com.au/itm/131671639600
Also to answer my own question from earlier, I ended up buying a grease gun off ebay and used some generic EPL2 grease on the front tie rod ends, seems fine.
  • Like 1
Is that what you did?
Struggling to find any cept from Kudos
http://www.kudosmotorsports.com/catalog/outer-rear-hicas-genuine-nissan-nissan-300zx-skyline-gts25-gts25-25gt-stagea-wgnc34-260rs-four-p-1350.html
Does that mean the hicas lock bar i have in the car is now redundant if i get your kit?
Yep my Hicas bushes were shagged and I still had Hicas, the eliminator kit gets rid of both in one hit.
Easy to install too, except removing the OEM steel sleeved bushing, which is always a pita.
  • 6 months later...
hi guys I'm just wondering if anyone knows if the front tie rod ends for a r34 gtt are the same as the rear as I need rear rack and tie rod ends for the rear. If anyone can show me where to get them that would be very helpful. I also have a hicas lock bar which is confusing to know which rack ends to buy all I can see are rack ends for hicas
The front and rear tie rod ends are not the same.
There are NO rear tie rod ends for non-HICAS cars.  There are no tie rods.  When the subframe is non-HICAS, the tie rods are replaced with "toe control arms" and the connection to the "steering arm" on the knuckle is not a taper ball joint.  It is a simple bush.  So it looks just like any other suspension arm.
So, if you have a lock bar, you still have tie rods.  If you need to replace the tie rod ends then you need to get HICAS (rear) tie rod ends, as there are no other types.
The smart thing to do is to buy a HICAS eliminator kit and freshen all that crap in the best way, selling the lock bar to some P-plater in the process.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
