had a coolent issue last week
come to my attenetion that my heater no longer works
i am guessing u are ment to blead it with the heater on so water goes into the heater core?
thanks in advance any one can confirm this and i go bleed it again
https://www.sau.com.au/forums/topic/316312-bleeding-coolent/
could be an issue with the heater core or the tap.
also remember that the heater won't put out hot air unless the car is fully up to temp, and if you put the heater on before the car is up to temp the car will take longer to come up to temp.
yeah.. normally the issue is "heater tap leaking, fan always blows hot air"
they can be blocked but doesnt happen often.. give the hoses a squeese and see if they feel clogged or anything
ooh, i have that. whenever the climate control is above the minimum temp (18oC) it blasts out hot air. is that easy to fix? (did a quick search in general maintenance but couldn't find much useful)
haha good find then hey?
off the top of my head there can be an issue with the r32 ambient air sensor (located under CD player) that makes it think the car is freezing cold
so maybe search that?
otherwise you might have to replace your heater.. :S i would just cut the heater lines and join them together
when you say that the car doesn't normally run very hot unless giving it a hard time, do you mean that the temp gauge shows it sitting lower than half way for normal driving? if yes then your thermostat is stuffed and needs replacing. the temp gauge should sit at about half way during normal driving, and should only take a few mins of driving to get there from a cold start.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
