ive read the diy thread on toluene and iam thinking about tuning my car on a mix of the stuff , but does anyone know how much of a measurable difference does it make say in rwkws, has anyone on this forum tuned there skylines on the stuff? what difference has it made? and if so with what other modifications?
rns11z what sought of power were you making and at what boost setting with the gt30 500hp turbo before and after running toluene? Dr Drift do you tune link aftermarket ecu? i spoke to ian weightman of amberley autos in dandenong and said he wouldnt touch it, he said that he only likes to tune apexi fc , autronic and motec!!!! what do you make of this? oh yead he reckons micro tech and wolf is crap too!! guess no one told him yet that there are a few skylines running 9 and 10 sec passes on these so-called crap ecus!! not every body has got a spare $4500 for motec! no matter how good they are.
RedLineGTR - Haven't tried to source it personnaly, but I beleive you buy it from BP at a 'cleaning' agent.... refer to other posts about it.
SMB315 - Yes you can run more boost, but you'll still be limited if running the standard ceramic wheels.
bigcarl- Yes I can and have tuned several link ecu's and I know why Ian won't tune them, for the same reason I won't recommend them. I only tune them if someone already has one. The older microtech's were fairly neanderthal but the new ones have full map matrix tuning on fuel and pretty good ignition mapping. Wolf looks very good on paper, only done a couple of these though with mixed thoughts. Personnaly my favourites are re-mapping the standard ECU's just wish i could do the RB25's economically.
Also, for reference my old 180sx was running a pretty much standard setup with a remapped ECU, 1.1 bar of boost, and a 20% Toluene mix... Result = 13.5 @ 98 MPH
Hey Pred..... what evil are you planning?
Dr Drift, I may be in a position for some toulene tuning in about 3-4 weeks all going well with the engine rebuild. Getting the PFCas recommended by a well known performance tuner so I will be looking for the right settings for the track (circuit)
dr drift, have you tunedany skylines with a gcg 450hp highflow st.1 turbo? if so what sought of power at what boost levels? do you think my turbo would still efficient up to say 1.5 bar of boost? on 98ron and 1.7 on 20% toluene with standard internals?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
