Cobb Ap
Godcla
 Share
Has anyone cleared maintenance reminders off their Instrument panel (not main Screen) using their AP..
I tried using the Clear re-learning/code menu on the AP.....but still pops-up every time you start the car
You dont need the cobb, you can clear the service reminders using the MFD, there is an option in there somewhere (did it myself not long ago). You may even be able to turn them off alltogether. Can check and report back if you cannot find them if you like.
Yea .....have cleared them from the main screen BUT it still pops up on the instrument panel....MFD...?
Ahh, sorry. Still pops up on the instrument panel? I never noticed that.
MFD = multi-function-display
Yea....removed the one on the MFD via it's Menu but the instrument panel still persists.....so I thought my Cobb AP
would clear it via the Clear Re-learn/codes menu........ :) but no luck using that either.
Edited by Godcla
OK Found the answer.....
" I'm assuming this is on the display in the middle of the tach and not the MFD.
scroll through the different displays, and go into the "service and maintenance" screen. Go into it and click "reset". You can adjust how long before it comes on again. "
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
