1992 S13 Silvia, Orange with RB20DET conversion
Year: 1992
Kilometers: ~92,000km
Colour: Orange with a very faint Gold Pearl only visible in direct sunlight
Rego: March 2011 (12 Months Rego)
Mods;
RB20DET engine conversion
TRUST TD06H-25G Turbo kit/stainless manifold (260rwkw at 18psi)
46mm External gate with screamer
Trust Adjustable Cam Gears w/ Trust Timing Belt
RB25DET gearbox "TUFF"
OS GIKEN Twin Plate Clutch (Extremely Bitey, no slip )
KAAZ 2WAY LSD (All bearings and seals in diff replaced for new)
Z32 AFM
SARD Fuel Pressure Regulator
SARD 720cc injectors
CUSTOM Stainless Intercooler Piping
HKS Pod Filter
BOSCH 044 External Pump
External Surge Tank
ASE Polished header tank
TRUST 600x300x115 Front mount "thick"
APEXI Power FC + Hand Controller
GREDDY e-01 boost controller with LCD screen
KAKIMOTO Regu 06&R cat back exhaust with Titanium look tip Sexy
5 Stud Hubs
R32 Skyline GTST 4 pots up front 2 pots up back
BREMBO front discs (New)
PROJECT Mu Street Pads front (New)
TEIN HE Drift Spec Coilovers (Fully Adjustable, OLD!!! Could do with rebuild)
BRIDE ZIEG III low max seats (Awesome seats, hard to find better for both looks and feel)
Matching BRIDE interior trim on doors, glove box, mats & gear boot
NARDI swede steering wheel (Bit worn)
CUSCO or SAFETY 21 HALF CAGE
CUSCO strut braces front and back
CUSCO Sway bars front and back
HICAS Lock Bar
HID Head Lights
Apexi RSM
DEFI White Face Boost Gauge, Oil Temp, Oil Pressure, Water Temp (*Not Currently Hooked Up* need to purchase sensors, has control unit all wired up and waiting)
PIVOT Security Start Button (Flashes blue, fancy :))
TRUST Gear Knob
Boot Mounted battery
Factory AERO front bar (NISMO BAR, paint flaking off in areas and has orange vinyl to cover up)
Volk/Rays Engineering TE37 Rims
18x8.5 +30 front
18x9.5 +40 rear
With 15mm bolt on spacers all round
GTR Style grill
Double Din CD Player/cassette (old Jap spec)
NO A/c condenser and lines removed, Heater and Fan still in working order with Digital control unit
Engineering certificate for Engine, Suspension and drive line, Engineers certificate is lodged with RTA and noted on registration.
There is probably more that I am forgetting
I have some spare parts im whilling to give away with the car too, like spare Starter motor, alternator, set of s14 stock wheels, standard sway bars, standard seats front and back, interior trim and carpet. I have a polished side mount inlet plenum to.
Also have a genuine brand new SUPERMADE body kit which may be thrown in to sweeten the deal but is not included in sale price.
PRICE: $17,900ono
Located in Newcastle, NSW
Call me on 0411 095 266 or send me a PM
No test pilots!!!!!! You will not get to drive the car unless you place a deposit
I am happy to take genuine buyers for a drive and show them how the car performs.
https://www.sau.com.au/forums/topic/316369-fs-orange-1992-s13-silvia-17900ono/
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
    • Well, it is an unusual noise. Use a 2 foot long bit of garden hose stuck in your ear as a stethoscope to pin it down to a definite location. We'll never work it out across the internet.
