I think TE37s are only available in +12? I think you'll need to roll guards for 10.5 +12, you will have more chance of not having to roll guards with 10.5 +22.
9.5 +12 you should be able to fit with a bit of camber. Safe choice is the 9.5 +22.
My car as reference, fronts are 8.5 +14 and rears are 10.5 +24
EDIT : Fronts are running 3.5-degrees camber, rears are around 3-degrees.
Edited by Kam-80
Looking for a set for my zed and was wondering whats the best offset in 18's? Will 18x9.5 +15 (F) and 18x10.5 +15 ® fit? It will be on standard suspension and don't want to roll guards if I don't have to. Cheers
Neither will fit unless you stretch a narrow tyre.
For TE37s +22 offset in those widths is the accepted limit for stock guards and camber.
Roll the gear guards and get camber arms on the front, and those things will fit just fine with a reasonabe-size tyre.
Yeah, the thing is f**ked.
Send me an email, from the email address you want to use, to 350z-tech-mod @ au-z.org (sans spaces, of course) with your desired user name.
Edited by scathing
I have no idea what offset I run, but my rear wheels are 10.5", and I have acres more space available: glancing at it, I don't think I'd have too much trouble fitting 11.5" - 12" rears, and I'm running very little negative camber from what I can tell... Is this normal?
mine are 10.5 +18 and i am running -2.5 deg camber, but my tyre us a 295 so that explains why. if u go and start stretching rubber possible to fit lower offsets such as negatives under there with ease. 19 x 11 +0 offet for starters ;)
Looks tough! What are they? At first, i thought they were drifteks but drifteks dont have those offsets. Bee-r b5? BTW youre on ocau?
Rota P45-R lol. had no complaints on the US forums so thought why not....
$3.4k delivered with tyres mounted/balanced.
Yup! I'm on ocau!
yo!
front: 18/19*9.5+12
rear: 18/19*10.5+12
proof:
as a reference in the pic, they are 19s with, 245/35 tyre front, and the rear is 275/35, you can easily run a 235 or 225 on the front and say a 255 on the rear if you want them stretched (but not crazy stretched lol) :D
edit - i just re-read your first post - to achieve "perfect" fitment it isnt all just about what wheel to run, is a culmination of wheel sizes/tyre sizes/suspension/wheel alignment/body work
F: 18x9.5 +22 with a 255/35 R18
R: 18x10.5 +22 with a 285/35 R18
Note that my rear guards aren't rolled, and I didn't have camber arms in the front at the time. That setup doesn't rub, and I've had that car cornering flat out. You can run a slightly lower offset, but I doubt +15 will fit without stretching a tyre.
Edited by scathing
11" +10 with 275/30 on the rear of my car standard height, the guards were munching the tyres on bumps and that.
So anything lower then +15 stretched tyres is a must, unless you wanna run some crazy camber or stiff as Fark springs lol
Edited by Beez35
OMG those rotas are HOT
can i ask if you need any mods to run those size rims?
like adjustable camber arms?
thnx
thanks! nope no mods at all. I'm running greddy s-type suspension as well, been dropped about 1-2" not sure....i want to drop it more but i might have driveway issues which i don't want.
Have to roll the rear guards if i want to drop the rear anymore though. No camber wear as such yet too.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
