Hey guys, not sure when this started as its been going on for a while now, not a huge issue but something id like to sort out anyway.
Basically, first thing in the morning starting the car it will turn over and then stall. Second time turning over the ignition will start the car no problem at all.
Running a powerfc, just recently put in brand new spark plugs, fuel filter was replaced recently also.
Furthermore, after the second time starting it turning it off and on theres no more issues with starting.
Any ideas? Could it possibly be the fuel pump?
edit: forgot to mention - doesnt matter if its a hot or cold day this doesnt seem to affect it either way
Edited by errno
https://www.sau.com.au/forums/topic/316397-r33-wont-start-on-first-try/
Hey mate,
very similar problem to what i had in my Honda years ago except my honda wouldnt stall. It just wouldnt start first try.
It was the fuel pump.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
