1992 R32 GTSt Skyline
Body Etc:
Black => Red, Full Respray In Japan
GTR Bodykit => Alloy Bonnet & Guards, Genuine N1 Front Bar, Rear Wing
Rolled Rear Guards to accomodate tyres
Sunroof
ABS
Engine & Other Mods:
RB20DET from EKW with 5 months warranty remaining
T3/4 Turbo => Custom made by ATS with 55mm TO4E Comp Wheel and 54mm RX7 Rear Wheel, Oversized wastgate valve, 0.8 Bar Actuator (NEW)
TRUST 3" Front mount Intercooler
GREDDY Intercooler Piping
Custom Made ECU with spare reprogrammable EPROMS
300ZX Air Flow Meter
600HP Bosch Motorsport Fuel Pump (NEW)
Exedy 5 Ceramic Button Clutch with Extreme Pressure Plate (NEW)
3" Turbo Back system with removable silencer (NEW Dump Pipe and Cat)
Aftermarket LSD(?)
Suspension:
Adjustable height coilovers
Adjustable Castor Bushes
Adjustable Camber Bushes
Some other bushes replaced with Urethane
Wheels & Tyres:
F: Zelda Tri Spokes 17x8" => 235/45/17
R: Zelda Tri Spokes 17x9" => 265/40/17
Interior:
Alpine Double Din In Dash 3 Disc Stacker/Tape/Tuner with 6ch 4v pre-outs, Equaliser, Track and Station Titleing
Greddy Boost Gauge
Genuine GTR Steering Wheel
Alloy Gear knob
History:
This car was originally built by Trial tuning spirit in japan before I imported it a couple of months ago. They were responsible for the full respray in the Bright Red it now wears as well as the GTR body kit, cooler and mags.. It was only complied just over a month ago and has since had full EPA and Vicroads inspections. The main reason I am selling this car is I am quite tall, and am unable to wear a helmet due to the limited roofspace with the sunroof. Since bringing it in I have worked all of the suspension with adjustable bushes and it handles superbly, replaced and modified a lot of the car. It is in excellent overall condition with only a couple of small dents and scratches. It also currently has 11 months rego and RWC.
Sam Cornell
0411 878 961
BETTER QUALITY PHOTO'S E-MAILED ON REQUEST
Im looking to buy in the next few weeks...
Id consider this at the right price and for an r32 i think id only pay around 18k at the most. I know this is a great example though...
How many k's and whats the insurance for you at the moment?
Dont tell me the reason you are selling that beauty is because you are too tall, if thats the case put aftermarket seats in with dropped seat rails.
It would seem you have put too much effort into the car, only to get rid of it because of a problem that you can remedy.
Are you after another R32 GTS-T , consider trade
R u serious bout trading for a 32 without a sunroof?? Ive got a 93 32 with a few mods including reprogramed computer 160rwkw.:uh-huh: :uh-huh:
I can b over in Melbourne next weekend. What sort off power does your's yours put out at the wheels?? Martin Donnon as done my computer 4 me:)
I could be interested in swapping my modded R32... I think it's going to have too much power for what I want. I'm not sure yet though...
See pics here: http://members.fortunecity.com/boosted32/
I still have to fit a new gearbox and sort out a stalling problem that happens every now and again when I come to a stop. It easily makes 210+rwkw depending on how much boost u run. Tuned by Tillbrook (martin donnan).
Power run made 170 kwkw with plenty left in it with some fine tuning of the ECU, looks like 200+ should be easy with 550cc injectors remap and more boost.
Current Best offer is $18,000
He told me he'd pay more but that's every cent he could scrape up...
Really need to get twenty as I have now spent way more than that...
PS: I'd be more than happy to continue working on it for whomever buys it, including remapping the ECU and larger injectors, stereo upgrades or anything :))
Doc.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
