Hey guys
For those of you like me who have the battery in the boot apparently we need sealed batteries or ones with the vents.
wrxhoon has been selling some from sydney in the group buy section for a few years. The code for the battery is SB1692 as you can see from his photos. I can't be assed organising my own group buy, as it means I have to go to the PO and post batteries around Melbourne, as well as dealing with crappy warranty issues as they come up. I found an online shop based in Melb with the same battery that is cheaper than the $220 delivered wrxhoon is advertising. The shop is Soanar Ecotech SB1692., and it's basically about $130-157 delivered depending on whether you buy 1, 3 or 5.
I am not sabotaging wrxhoon, nor am I promoting this seller. However, after I found the site when looking for a Vic distributor, I felt I needed to let everyone know about the better deal. I find it ridiculous that I have to pay $150 at Supercheap Auto to get a home-brand non-sealed heavy-as shit battery with lower amps. I emailed the Soanar guy and he said it comes with 12 month warranty. Has anyone had any experience with Soanar Ecotech?
The specs are
BATT SLA 12V 40AH
SB1692.jpg40 Amp Hour 12 Volt
  • Size: 197 (L) x 166 (W) x 170 (H) mm
  • Charge current: 4A for 10 to 14 hours
  • Discharge Current: 2A for 20 hours
Capacity:
  • 20hr rate: (2A) 40.0AH
  • 10hr rate: (3.8A) 38.0AH
  • 5 hr rate: (6.8A) 34.0AH
  • 1 hr rate: (24A) 24.0AH
  • Int resistance - fully charged: 10m.
Constant Voltage Charge
Initial Charging current: < 12A
Cycle:
  • Voltage: 14.40V ~ 15.00V @ 20°C
  • Temp coefficient: -30mV/ °C
Standby:
  • Voltage: 13.50 ~ 13.80V @ 20°C
  • Temp Coefficient: -20mV/ °C
  • Weight: 14.0kg
https://www.sau.com.au/forums/topic/316436-sealed-batteries/
The company I work for buys parts from Soanar all the time, they are good to deal with and generally ok priced.
This battery appears to be a generic chinese sealed battery which we use something very similar for our UPS backup systems, I'm not saying there is anything wrong with this battery but I don't think this battery is design to supply large starting currents.
I would suggest looking at the automotive sealed units such as (from memory) Pulse branded ones that come from the same factory as very expensive Oddysee.
nope, plenty of ppl here use pulse which are probably best bang for buck but i spent 300bux and bought an optima yellowtop battery instead..
i've got a yellow top too, and in need of a new one after 5 years. i got quoted 350. where'd you pick yours up from for 300?
this is not even in the same class as an Optima. This is just a sealed Lead Acid battery, it will weigh the same as your normal Exide you buy at K-Mart but this one is not made for cars. It is for a UPS, Solar station etc. hence the reason it has no CCA (cold cranking amps) rating on it.
For a battery to be legal in the boot it has to be a sealed Gel type (optima) or a euro vented type lead acid. This one doesn't show a vent but I bet it has one because a lead acid battery of any type will need to vent excess gasses that are created, this is the reason that if you have a lead acid battery in your boot it needs to vent outside of the car or it can possibly cause a fire if the gasses ignite.
IMO, save your money a little longer and buy a yellow top.
Hmm... ok
Not sure WTH wrxhoon is selling then, because I am sure this is identical.
My sound system doesn't need to run while the engine is off, and I don't power a fridge either with my battery. To save money shouldn't I just get a cranking battery like a red-top, instead of a crank/deep cycle hybrid like the yellowtop?
And does anyone know which optima models fit into an R34 GTR without having to modify anything?
Thanks heaps
http://www.skylinesaustralia.com/forums/Se...es-t311699.html
Looks to be the same battery but different colour casing.
This could be related/important as the cream colour could be suited for high current discharge.
Ummm. ... the black one in the pic is the Odyssey car batter. The cream one is the one he is selling.
But I take your point.
The black battery I was refering to was the black DiaMec that you have posted the specs to in this thread not the Oddyssey.
I had a look on the manufactures website couldn't find anything about cream vs black look to be the same to me.
http://www.diamec.com/e/default_home.asp
Listed as having maximum discharge current of 600A for 5 seconds.
Could be ok and given the information in the other thread (assuming the cream DiaMec and black DiaMec are the same) probably worth the risk, if you use it let us know how it goes.
  • 4 months later...
Just for info I have had the diamec SB1692 in my R33 for 5 years.
It started to loose charge so I took out the black plastic covers at the top (2) and there are 6 small plugs that you can pry out with small screwdriver. Where some goggles in case it spits acid at you (not likely but good to be careful).
I added a small amount of INOX battery conditioner to each cell (about 10ml) and some tap water (probably another 20ml).
I then put it on charge overnight (best to leave the plugs out whilst charging), place a rag underneath it and do this in a VENTED area.
Check charge on battery (should be around 12.5v and install in vehicle.
Its now back better than ever.
Real test will be after a week without driving it to see if it still has charge.
Battery world were surprised it even worked when it was the wrong style of battery for cranking.
However smaller SLAs similar to this are used in all the battery boosters!
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
