Hey guys, selling my beloved r34 that is a real pleasure to drive.
reason for selling is because i am investing in a franchise with my brother so need the funds for business.
i will be getting more piks up of the car tomorrow but for now ill post what i can.
car will be sold without the numberplates and standard issue plates will be supplied upon sale.
comes with 10months rego and car has been well taken care of with regular servicing and only best parts used.
(100k service was carried out at racepace)
mods include the following:
turbosmart pro gate 50mm
garrett gt35/40 (.64 rear)
braided oil and water lines with pro flow fittings
hybrid front mount intercooler
custom one piece dump to cat.
cat back stainless exhaust (unsure on brand)
800cc injectors on a new fuel rail
vipec ecu
boost controller
2 x bosch 044 fuel pumps
surge tank (all braided lines connected with pro flow fitting)
custom catch can
new fuel lines from fuel tank to surge tank to engine.
jim berry full monty clutch (rebuilt 2000km ago)
gearbox rebuilt with new bearings and synchros 2000km ago
splitfire coil packs
tein coilover suspension height adjustable
front and rear 6inch splits (kickers)
focal amp
pioneer 12inch sub
jvc double din touch screen dvd player
sunroof
A/C
dba upgraded cross drilled and slotted rotors front and rear
lenso project d wheels (18x10 front and rear)
guards have been lipped
xenon headlights
GENUINE NISMO LED TAIL LIGHTS.
spares it comes with:
complete standard turbo back exhaust
standard oil water lines
standard cat
catco metal hi flow cat
2 x brand new bucket seats which i havent fitted as i never got around to getting rails
standard ecu with nistune board (can be plugged in as vipec is a plug in for r34 gtt)
standard air flow meter
and there may be a few things that i have missed.
car has made 356rwkw on e85 fuel.
dyno printout will be put up tomorrow also along with more pictures.
also, car can be dyno tuned on 98fuel at no extra cost.
PRICE: $27,000 neg.
you can contact me via email, call or sms.
Baset: 0431 537 750
dont hesitate to call as im glad to answer all questions and allow people for an inspection.
note: please no comments unless your interested or have something good to say, thanks in advance.
Edited by WARLORD BAS
https://www.sau.com.au/forums/topic/316445-fs-melb-r34-gtt-356rwkw/
Guys ive gotta say, this is seriously one of the best packages ive ever experienced...
Bas is always washing, polishing, maintaining this car whether it needs it or not.
Not to mention the INSANE amount of go this thing has, with midrange and top end kick to blow anything off the road, all done by such a reputable workshop.
Gonna miss this thing man, sad to see it go. Bloody tuff.
:happy:
hey mate, awesome looking car.. if i may ask, appart from the guards being lipped, did u have any other problems fitting the wheels.. and whats the offsets on them?? cheers
thanks for the kind words matt, but yes will be sad to see it go.
mick, there was no other mods i had to do in order to get the wheels on and the offset is +22 :D
dont be shy to call and make an offer guys.
  • 1 month later...
  • 4 weeks later...
sorry guys lost interest in selling it but now ill take pictures and drop the price of the car.
engine bay looks pretty stealth apart from the pro gate but lucky its black in colour and not the blue one.
will take piks asap.
and price is dropped to a bargain of $22000
YES having a sunroof is the bomb :(
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
