i have had k&n with no problems all i did was go down to my local speed shop and look for the biggest 1 that would fit with out going over board then i got the guy to find that filter with the correct diameter pipe. swapped the filter on the spot it fitted and i was on my way.
ppl have problems with k&n when the re oil them after cleaning they put to much oil and then u get oil on the AFM but if this happens u just spray it with AFM cleaner (u should do this at filter change any way)
may i recommend a metal pod filter adapter because they dont brake i had one brake on me 4 no reason so i fixed it with super glue and drove down to auto1 got a new one and now no problems
and dont 4get to make a filter bracket to secure everything down because if u dont do this u will not pass pits
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5180522
Sounds good guys. I'll have a look at the diameter of existing one and go from there. Prob need a new AFM anyway. Had issues in underground carparks (as well as other times) where my revs would fluctuate badly - from 200 to 1500, then car would stall when i gave it a little gas. Had it data-streamed but nothing came up.......weird. Hasn't happened in a while now though.
Anyway, i'll take into account the advice given
cheers
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5181156
Got the proof from an independent source to back up your claim?
(website???)
I'd be interested in that too the last time I saw a pod survey concluding that the best filtration was with Apexi it later turned out the the survey was done by guess who--- ah hem, wouldn't have been Apexi by any chance-- :laugh: yup.
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5183386
(website???)
I'd be interested in that too the last time I saw a pod survey concluding that the best filtration was with Apexi it later turned out the the survey was done by guess who--- ah hem, wouldn't have been Apexi by any chance-- :ermm: yup.
It's a PDF File from an Auto Salon magazine.
I LOL! everytime some post it and SAU shit on HKS filters, yet some of the worlds fastest Skylines in Japan use HKS filters.
Auto Salon have mechanics / engineers..?
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5183591
Ah Ha-- :ermm: definately gospel , this from a publication that (in it's genre) has the worst art direction, worst type selection, worst photography,worst editorial, the list of worst is endless when it comes to this rag , it was recently sold, - just before it went broke, -I wish the new proprietor the best of luck with this dog imo they are going to need it.
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5183680
Hah!
Yep, that's it.
Surprisingly I have on Auto Salon rag, which was given to me in 2008 and it had a decent write up on track cars and the High Octane / Yokohama ADVAN R32 GTR.
The rest was just wannabe Fast and the Furious car meet up shit.
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5183708
That doesnt mean they are any good.
They appear to have the best flow characteristics, but lack the filtration. They are just a piece of green foam haha.
Japs are like americans, Name means everytihng :ermm:
Each to their own i guess. I read it on the internet they are crap. So it must be true!
https://www.sau.com.au/forums/topic/316464-pod-filter/#findComment-5183712
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
