Well after sleepless nights and a lot of thought i'm thinking of selling the 32. Its one killer of a car and a lot of fun to drive. Turns heads everywhere it goes. At the moment its just EOI to see who's interested in it. I would like to get a Stagea. :)
The car has been on show at Auto Salon in Adelaide by the previous owner. And has also been taken to other various car shows including AJD 09 down at Glenelg.
It's previously been tuned by Jeff at SpeedLab and just recently been given a quick tune at Southern HiTech Dyno and is sitting nicely on 200rwkw on low boost.
I'm only the 2nd owner in Australia and most know this car very well and have seen it out and about quite a bit.
This is the 1989 model which is by far the best model as the laws for modifying it arent as strict. The compliancing laws, exhaust emissions tests and other tests are not as tough when moddifying this model hence why people never register that they have installed a larger engine eg. RB25. The RB25 in this car is registered to the car and has been through regency to do so with all required paperwork on hand.
Make: Nissan
Model: 1989 R32 4 Door
Transmission: 5 speed manual
Colour: Bayside Blue
Currently registered: July 2010
Price: $16000
Contact: PM me or email me [email protected]
Engine/Body
RB25DET making a nice 200rwkw. Registered to the car with all compliance and regency papers
R32 GTR brake upgrade to suit compliancing of the RB25DET
Red stuff brake pads all round
Cushion button clutch
115,000km on the chassis
No oil leaks
Genuine GTR front bar
Front rims 18x8" (Pictured below)
Rear rims 18x11" with mad offset. Within the legal requirements (Pictured below)
Bayside Blue respray done by Spikes Auto
Front mount intercooler
Aftermarket fuel pump
POD filter secured to the chassis
Remapped R32 ECU for RB25
Rev limiter reset
NO boost cut
NO top speed cut
Custom top mount turbo setup. Very interesting setup. Check Pics.
Turbosmart pro gate 38 external wastegate
Screamer pipe (sounds awesome when hitting full boost)
Full exhaust with custom dump pipe
Tein HA coilovers (Fully adjustable)
Cusco 35mm sway bars
Flared rear gaurds to house 18x11" rims (Pictured below)
Full pager alarm with Turbo timer, Remote start, Engine shut down. Works up to 1000m away.
Just been serviced by Southern HiTech Dyno with all new oils throughout the car, all new platinum spark plugs, new brake pads all round and new radiator.
Interior
NISMO 260kph dash cluster
MOMO steering wheel
Upgraded R32 interior with no rips or tears
Pioneer head unit with motorised face. Ipod cable, USB cable, AUX cable.
Previous owner had the stereo recorded at 126.9Db at Street Machine Show 'n' Shine now pushing out even more with the new setup
2x JBL amps in the boot
2x JBL subs in custom made box
6.5" Clarion Fronts with door mounted tweeters
6.5" Clarion Rears
i personally built this car and still dearly miss it.
if you need any details on the car feel free to pm me and i can fill ppl in on what itwas like when i had it.
and the ONLY reason i sold the best car i have ever owned or built was to buy a house.
if it wasnt for that i would still own it and if i had the cash i would buy it back and further mod it.
best power i got out of this car was 240rwkw on 14psi with the to4 pictured above but was sold with rb20 turbo pushin 200rwkw on 11psi.
with a few extra mods this car could be a weapon for street or drift.
also when i had it i did shim the diff. only added 1 shim as i didnt want it locked.
car was made to be admired and not defected. i owned it for approx just under 2 years and never defected in my hands.
who ever buys this car will not be dissapointed and i hope like hell they look after it like brad did.
kudos to u brad for keeping it in the condition that i left it in :D
  • 3 weeks later...
Nice car!
Which turbo is it currently running, and can it be converted from top-mount to low mount?
Just wondering about getting a setup like this engineered and legal in VIC.
Cheers
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
