Im looking at buying one of these for my R33 and just thought I'd do some research in the mean time
I have stock turbo at the moment with X-Force exhaust, turbo back. It looks like the dump will fit directly to the back of the RB25 version of the 2835 but thought I'd ask if someon knows for sure first hand
Also I have a front facing plenum setup with a plumback arangement that is a bit different and just wondering about the inlet size of the turbo cause I can quite work out how its set up and what size it is
At the moment I have a 45 degree silicon bend coming off my turbo (2.5 inch) that goes to my intake pipe which expands to 3 inch before the AFM. The pipe has been customised to suit the stock rocker cover breater and have a plumback BOV ported into it.
Any help, pictures etc would be much appreciated :)
Thanks
Callan
https://www.sau.com.au/forums/topic/316523-info-on-hks-gt2835-pro-s-turbo-kit/
yeh? I was just hoping i could use my existing dump but oh well.
Think im gonna have to try and work out what to do with the intake pipe when i get the turbo but yeah think its just gonna be a bit of mucking around
How did you rate difficulty/problems with installation? Anything else I should know?
Thanks guys
A new intake pipe shouldn't be much of a worry.
The only other thing is the dump position, might not be exactly the same meaning a new pipe to the CAT...
But otherwise nothing a exhaust shop can't do (if you can't), and same for the intake piping really :yes:
Just sell the old dump - more cash in your pocket!
Pro S kit comes with an intake pipe too.
The dump will fit up perfectly with a stock type front pipe, When i helped a mate fit his he had a second hand trust dump which fit fine
Installation is a breeze. The hardest part is getting the water feed behind the head in.
yeah the only problem with the intake pipe provided is my pretty.... i dunno if ud call it complex but yeah its a bit tight, BOV plumback setup with my front facing plenum... Guess ill just see how i go and if i have to get a new pipe made up or get something modded then it shouldnt be to major
thanks guys, now i know the possible problems im up against.
whats the deal with the water feed line? just a bastard of a spot to get to?
200 to 260 is a big jump, though you'd only notice it after like 4500-5krpm, but it really must have felt like you were being glued to the chair after that :)
I'm curious though, isn't the 2835 a high mount? If so, why would the intake change? I mean, the piping won't match exactly, but it isn't like there is a lack of room in that part of the engine bay.
plus my stock turbo only has a 2 inch (or is it 2.5"?) inlet so my intake pipe is much smaller but also custom made to suit my setup so the hks item will have to be modded or ill have to change it with another custom one
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
