For Sale
Well cared for R33 GTST, QM1 (white)
Imported this car and have owned since its arrival in Australia at around 86000km. Time to sell as I move on to better things. Car has done mostly highway km's here but I have now moved to the city and it needs to go. Car was previously making 280kw but have now removed the larger turbos and put the factory single back on. Motor was rebuilt for the big setup and only did around 10,000km making that power as I purchased a gtr.
[/size]
12 months rego, new tyres
118,000km's
[/size]
Motor rebuilt at 100,000km with:
GTR rods,
new Nissan pistons,
acl bearings,
new water and oil pumps.
Exedy H/D clutch
Greddy Style plenum
Trust peII exhaust
Metalcat
New standard Turbo
Tomei fuel pump with nismo damper
Greddy intercooler kit
Adjustable cam gear
Ohlins coilovers
Hicas removed
New Federal 595ss
Rays 17" rims 5 spoke and 3 spoke rims- you can have both sets
DBA rotors
QFM A1RM pads
Braided Brake lines
RBF600 brake fluid
Front and rear swaybars track spec
Interior istop notch, no ciggarette burns only small rip on the drivers seat at the hip. Have a spare series II seat you can have,
Plus everything I have forgotten, and a lot of spares sitting here too including spare boot (different wings) spare sets of wheels, spare everything pretty much. This car has been great to me and I will miss it. It has been serviced religiously and has never skipped a beat.
10,000 ono. Will consider swaps for a ute or other to tow with. cash either way
https://www.sau.com.au/forums/topic/316528-white-r33-sydney-12-mths-rego/
  • 2 months later...
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
