No offense taken Say what you like but considering there are auto r33 and nonners 300 drivers on here whinging about traction makes me wonder..
Fair call mate
Oh, and I would just like to point out that I now drive a manual houseboat. The auto is now in a pickles yard somewhere. My sig lies!
About time you man'ed up :) toot toot!!!
  • Replies 91
Scariest moment was when my sister was driving it down a hill in heavy rain, took a good 100 metres to stop from 60kmph because she was braking too hard and spent most of the time sliding down the hill. We came to a stop about 4 metres before the roundabout
You let your sister drive your skyline in the rain?! :)
The only people who get to drive my skyline other than me, are my two mechanic mates and my two suspension guys (Bard and Muttley), and maybe Paolo because he let me drive his beast :laugh:
The only people who get to drive my skyline other than me, are my two mechanic mates and my two suspension guys (Bard and Muttley), and maybe Paolo because he let me drive his beast :)
Yeah we sortof share cars, not in the rain though anymore lol
She likes driving my car because its faster and more fun to drive than hers, and I lke driving her car because it can go over speedbumps and uses half as much fuel
I have 265/35/zr18 Toyo T1rs which are brand new and awesome.
Except I just got yellow stickered, so the tyres do not comply, along with me having to get emissions testing and permits for everything under the bonnet :)
I got Toyo R1R 195/50/15 at the rear and Yokohama Parada Spec-2 195/50/15 at the front... 38psi rear, 36psi front...
They are damn good on dry, but on wets, the Toyo loves to slide out easily but the Yokohama still grips nicely at the front, annoying (BUT FUN) when driving around corners especially in my AE86 lol...
Give it some more revs before you drop the clutch..
hey mate,
is that a serious suggestion?
i checked rear suspension bushes for wear they all seem OK, not cracked etc.
car has std suspension & the clutch is h/d but still organic and as stated the problem is only up to 20km/h then it's fine, unless i boot it obviously
not trying to wheelspin, just need to get momentum up so i don't hold up the flow of traffic :D
thanks heaps,
-dave
hey mate,
thanks heaps,
-dave
Oh if you don't want to wheelspin then don't give it more revs :blush:
Not much you can do about holding up traffic, srsly, fk them.
Axle tramp can be from a few reasons but mostly it's old suspension components.
The only people who get to drive my skyline other than me, are my two mechanic mates and my two suspension guys (Bard and Muttley), and maybe Paolo because he let me drive his beast :P
Well Bubba I'm just a girl and my housemate let's me drive his cars quite often, not all girls a bad drivers. They have plenty of poke and then some.
Jes guys, my wife drives her 33 auto and is turbo everyday with our baby in back and never has had a drama with loosing traction one bit. IMO, it's got to be the way you are driving. My 32 has 430 at the rears and never had any issues. Its drivers on the road who panic and drop in speed when it rains who cause accidents. If ya can't handle a little bit of water then you shouldn't be driving.
To be perfectly honest...if you guys are losing it in the rain you need to stop being dick heads and slow down...
I read up to about here and then just flat out thought /agree
If you are questioning how you should be driving in the rain, you are driving wrong to begin with and need to slow the f**k down and take your time, and as suggested by someone else, sell your car.
In terms of rubber though, I have a set of Falken ZE912 235/40/18's on my car. Have skid-panned it only 1 time with this rubber and it is some of the best rubber I have driven on. So much lateral grip in the dry AND in the wet.
Edited by stormtrooper
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
