Hey forum I am really puzzled as some weird issues are going on with my ride. Can see my other post, http://www.skylinesaustralia.com/forums/We...No-t316378.html, to get up to speed. In short had an issue car missing on cylinder 3 and seemed to stem to other cylinders. To solve this problem I removed the pfc and tried the stock ecu just as a test, to my amazement the car started all cylinders were firing and the afr's were in the high 16's to mid 17's. took the car on a cruise while watching the afr's and they were pretty normal under vacuum normal cruise load they were varying but trying to stay within the 14.7 range. On decel the car pops and gurgles and will get a small backfire from time to time but no black smoke and afr's seem normal. Now here is the messed up part the car has a q45, z32, supposed high flowed injectors to 650 they are said to be flow matched within 1.3% of each other, a 35r and aftermarket plenum with exhaust manifold. How the hell is this possible? How can the stock ecu start the car with the z32 and bigger injectors much less run smoothly? I even gave it a bit of a boot in second gear to see where boost started to build, plus check out the afr's, and positive pressure began at 3000rpm which was to be expected and to my surprise afr's were in the 11's, I think, this is flat footed in second gear starting from around 1500 or so rpm. Will make sure about the afr readings tomorrow after another drive. The car idles kinda lumpy but I am using old spark plugs that are a variety of heat ranges, types and one or two of them were the ones were the cylinders were not firing so they were black with soot and got could smell the fuel on them, gave them a good clean up before putting them back in though and made sure all were firing. Will make sure and buy a new set tomorrow and change them out to see if that helps with the bumpy idle. Besides the one time it stalled when decelerating with my foot on the clutch and when starting it up after getting petrol it drives fine, noticed at startup I might have to give it a rev to clear it up and get the juices flowing but aftert that it idles great for what suppose to be in it. What if any explanation can you guys give me? I am suspecting tht the injectors are not high flowed 650's rather just a set of stock injectors, they are red with a single hole for fuel delivery. If that explains the injectors then how can the ecu handle the z32 afm, how can it start idle and run fine with it installed?
Edited by Daboss
https://www.sau.com.au/forums/topic/316558-wtf/
Lol wow forum never ceases to amaze me. Here I am thinking I have a hot topic, 5 replies and so quickly but everyone is commenting on how it is written. WOW!!!!! Anyway's here I go again
Hey forum I am really puzzled as some weird issues are going on with my ride. Check my other post to get up to speed, http://www.skylinesaustralia.com/forums/We...No-t316378.html. Quick version, car was missing on cylinder 3 so I did all the test I could think of with no luck, after test conculded another cylinder now was missing. For testing purposes I removed the pfc and tried the stock ecu, to my amazement the car started all cylinders were firing and the afr's were in the high 16's to mid 17's. Let it idle for awhile nothing seemed wrong so took the car on a cruise while watching the afr's and they were pretty normal. Light to mid load the afr's were behaving normally trying to stay within the 14.7 range. On decel the car popsed, gurgled and will get a small backfire from time to time, but no black smoke and afr's seemed normal.
Now here is the messed up part, the car has a q45, z32, supposed high flowed injectors, a 35r, aftermarket plenum and exhaust manifold. How the hell is this possible? How can the stock ecu start the car with the z32 and bigger injectors much less run smoothly? I even gave it a bit of a boot in second gear to see where boost started to build and to check out the afr's. Positive pressure began at 3000rpm which was to be expected and to my surprise afr's were in the 11's to 12 range at wide open throttle, this is flat footed in second gear starting from around 1500 or so rpm. Will make sure about the afr readings tomorrow after another drive. The car idles kinda lumpy but I am using old spark plugs that are a variety of heat ranges, types and one or two of them came from the cylinders that were not firing. They were black with soot and got could smell the fuel on them, but I gave them a good clean up before putting them back and made sure they were giving spark. I am buying a new set today and change them out to see if that helps with the bumpy idle.
Issues I am having if you can call it that are: 1)The car stalled when decelerating with my foot on the clutch. 2)When starting the car up it idles really crappy, I have to give it a rev to clear it up and that seems to get everything cleared and flowing. The idles is a bit bumpy but great considering it is the stock ecu and the upgrades I have.
What if any explanation can you guys give me? I am suspecting that the injectors are not high flowed 650's rather just a set of stock injectors. They are red with a single hole for fuel delivery. That would explain why I am not running rich. The other burning question is how can the stock ecu start and run fine with z32 installed. Abit long winded, but just wanted to give as much info as possible.
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179071
  Daboss said:
Hey Guys,
I am really puzzled as some weird issues are going on with my ride (Check my other post to get up to speed, http://www.skylinesaustralia.com/forums/We...No-t316378.html.)
Quick version:
Car was missing on cylinder 3 so I did all the test I could think of with no luck. After test concluded, another cylinder now was missing.
For testing purposes I removed the pfc and tried the stock ecu. To my amazement the car started, all cylinders were firing and the afr's were in the high 16's to mid 17's.
I let it idle for awhile nothing seemed wrong so I took the car on a cruise while watching the afr's, and they were pretty normal.
Light to mid load the afr's were behaving normally, trying to stay within the 14.7 range. On deceleration the car popped, gurgled and will get a small backfire from time to time, but no black smoke and afr's seemed normal.
Now here is the messed up part!
The car has a q45, z32, supposed high flowed injectors, a 35r, aftermarket plenum and exhaust manifold.
Positive pressure began at 3000rpm which was to be expected and to my surprise afr's were in the 11's to 12 range at WOT, this is flat footed in second gear starting from around 1500 or so rpm.
The car idles kinda lumpy but I am using old spark plugs that are a variety of heat ranges, types and one or two of them came from the cylinders that were not firing. They were black with soot and got could smell the fuel on them, but I gave them a good clean up before putting them back and made sure they were giving spark. I am buying a new set today and will change them out to see if that helps with the bumpy idle.
The issues I am having (if you can call it that) are:
2)When starting the car up, it idles really crappy, I have to give it a rev to clear it up and that seems to get everything cleared and flowing. The idles is a bit bumpy but great considering it is the stock ecu and the upgrades I have.
Cheers,
Guythatcantformat :yes:
Edited by Lukas 33
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179188
All I can say is take it to a tuner. You should NEVER perform such mods and not take it to a tuner unless you can tune it yourself. From reading other threads, changing injectors shouldn't make any difference per se, as long as you adjust them to a less duty cycle, but certainly a different AFM would make a huge difference even if you adjust it (they are fiddly).
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179347
Changing injectors will make it run very rich. It will be injector fuel as a percentage thinking the injectors are 380cc :S
I find it VERY hard to believe you struck it lucky with the z32 and injector sizing, but I don't disagree that its possible.
Man on the PFC you can easily tell the ecu that u have a z32 and calibrate your injectors, so chuck the PFC back in, get some new plugs and try again.
I dont see how the hell the car runs better on a stock ecu, especially with a damn 35r!
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179356
Yea, so basically you need the PFC and a tune to make it work :yes: The main reason the injectors probably work stock is a degrade in the line/power cables so that the larger injectors are actually running close to stock. But again impossible to tell really, so tune it ;)
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179396
Ok thanks for the advice guys and thank you lukas 33. Honestly I probably would have never formatted it that way. Do you possibly think the injectors are just standard ones? I am going to put the pfc back in with the 555's it was calibrated for and hopefully the miss stays away this time. I can't get it tuned cause there are no real tuners were I live.
I know the pfc is the better ecu its just that with it installed the cylinders missed and I didnt want to reinstall it and have it all fudged up again. I got the new o-ring for the 555 injector that was missing its own and a new set of spark plugs Will be replacing the ecu, injectors and spark plugs in a few and see how it works out. I hope all goes well.
My thoughts exactly lukas how the hell is it working so well with stock ecu? Anways I am going to replace everything I switched and see how it works out. Will keep you guys posted.
Thanks once again for your help.
Edited by Daboss
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5179496
its to do with the % increase in injector size and % de crease in what what your maf reads . if you made your injectors 50% bigger and the maf had 50% lower resolution itll run ..
used to happen with sr20 . put in 555cc injectors and a z32 and it was able to run quite well
https://www.sau.com.au/forums/topic/316558-wtf/#findComment-5180428
    • Yes, I know馃檮 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole馃ぃ
    • You鈥檒l be very upset when you bust that too not to mention the gearing totally sucks. Don鈥檛 do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30掳 silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30掳 silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
