Just listing some items for sale off my SR20. Reason for sale is my motor dropped 2 valves so instead of repair I'm carrying out a RB26dett conversion.
Here's the list;
T67 25g turbo, 10cm rear housing,6boost manifold has mitsubishi flange (had T67 mounted) will suit TD06, T67 and others, 50mm Greddy waste gate, dump, front pipe, oil lines and intake and intercooler piping. $3500. May separate manifold if reuired.
Z32 gearbox conversion plate with Z32 gearbox, shifter, crossmember. Everything you need to carry out the conversion for your SR20. Will require tail shaft to be modified. Includes Starter motor. $1600
Apexi power fc to suit s13 sr20det with hand contoller and engine loom. Currently tuned for [email protected] bar, 850cc injectors on forged motor. With required sensors. $1300
K&N pod filter $50
Altenator $120
Power steering pump $80
Billet SR20 spark plug cover $70
Pm me if you want to make an offer or my number is 0419 856 391
Everything is located in Alice Springs and freight can be arranged.
https://www.sau.com.au/forums/topic/316583-sr-fruit/
Also got sr ignition module, make an offer
If someone wants the turbo only I will seperate for 1600 plus freight. No shaft play and in very good condition.
I'll also have intercooler and few other things once I get everything transferred over.
Edited by fmlycar
https://www.sau.com.au/forums/topic/316583-sr-fruit/#findComment-5198940
  • 4 weeks later...
I still have alternator, power steering pump, nismo engine mounts, z32 gearbox conversion, hybrid copy intercooler, 6 boost turbo manifold with mitsubishi flange. All these parts need to go now. Need the space so I can start my RB26DETT conversion. Make an offer, I'll freight to you.
https://www.sau.com.au/forums/topic/316583-sr-fruit/#findComment-5279626
Thanks Stuart.
Gearbox conversion is on hold till the end of the month pending payment.
Manifold and accessories still need a new home. I'll put the manifold and dump as a package for 1200 freighted anywhere is OZ.
https://www.sau.com.au/forums/topic/316583-sr-fruit/#findComment-5305917
  • 4 weeks later...
  • 4 weeks later...
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
