The series one version of the Stagea was first produced in October 1966 until late 1998
LOLZ!
1966 never seen one that old.
Thanks for what I think are meant to be positive comments. It is/was my first attempt at a website so there were always bound to be mistakes. In fact almost all the info that was wrong came from wikipedia .
Will be getting an update soon .
Good info. While I've had an RS Four since 2006, have just acquired a 25G for my son. Out here you must have an open, 3 yrs experience, before you can drive a Turbo.
I noticed you listed the 25G as "Basic". Well apart from the tweeters in the A pillars and the electric tailgate closer it has all the refinements of the RS Four.
The way these cars were originally bought JDM is a long way from the basic models.
The nice part about the two Stags is that they loo identical, even down to the N/A grille. LOL
didn't realise it was your site
seems like there is a bif of info on there
needs some bits and pieces about the rs4s's :(
Because of age the RS Four S has only been available in the uk recently so there not much info on this model over here yet.
Edited by RSVFOURUK
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
