Hey guys
I've got an r32 gts-t and I've got some 18x11.5" +26 work vs-xx wheels coming, and I need rear wide fenders to fit them.(preferably +50mm)
I've rang savanna motorsports the Origin dealer for aus, and they informed me that Origin do not make wide rear over fenders for the r32.
So I'm begging you guys to lead me in the right direction for some GOOD quality rear fenders. I want them to fit straight up, I don't want to have to stuff around with fuel filler in particular. Please, do you know any good brands?
https://www.sau.com.au/forums/topic/316641-r32-gts-t-wide-fenders/
*sigh* you saw a set of wheels on YAJ and went "OMG fullysick dishhh uleh I must have it!" didn't you?
What you probably didn't account for is that 11.5 +26 makes your wheels sit around 2 inches too far inside so it will hit your shocks unless you run some chronic spacers. This is in addition to sticking out of your guards by about 30mm, so lets say you space out the wheel by about 30mm to clear the shocks, you'll then need a 60mm overfender to clear the rim (run stretched tyres and you should be able to sit it at a decent height and not collect the fibreglass fender with your tyre and send it all to hell... or look like poser and run it at 4WD height).
rear fenders NEVER fit straight up. not even japanese ones. I imported a set of D-Max ones straight out of japan and even then we had to trim the fibreglass and sand out the imperfections etc.
http://www.dmax-cs.com/aero/r32/index.html
http://page9.auctions.yahoo.co.jp/jp/auction/k121228644
Nice buy from Import Monster though, and 155,000Y isn't actually that bad a price for em. But I wouldn't wanna be the guy trying to shoehorn them under an R32 GTSt, especially the 10.5 +26 in the front, without resorting to something like a BN widebody kit.
How the hell did u find the auction I got my wheels from haha. Yes a very good buy, and I've seen same wheels on gtr32 but 10.5 front n rear, and I wanted rears to be slightly wider I was actually waiting for the wheels for a while. I've got gtr front end already just need rears. A mate has some viva garage ones and I held them up and they needs about an inch cut out front and rear of wheel arch, they are the complete wrong size
lol do a search for "VIVA garage fenders" in this section, and you'll find pics that I took of a set that were delivered to me.
  • 3 months later...
11.5 +26 wow, ive got not even 1 cm clearance on my coilovers with 10.5 +/- 0, your guna one BIG spacer my friend
thats no spacers, bolted straight onto the hub :/ i bein offered 5g for these wheels i said noooo f*kin way hahaha they are huge, them rubbers are 295 streched on, cant beat that
yea definately would hav taken the cash and ran. IMO all the aftermarket fenders out there ruin the clean lines of the r32, they just make the car look silly even when done to a high standard. get some rims that actually fit and dont make it look like a clown car.
GTR oem guards FTW
  • 3 years later...
Sorry to dig up this thread.. Didn't want to make a new one.. Did a search and found some useful info.
But, not exactly what I'm after.
I may of answered my own question.. With the stock 32 gtst wheel (16x6.5 unsure of offset)
I will have to widen/role my guards for a set of 32 GTR wheels? (16x8 +30)
Thanks guys.
Couple hundred too much IMO. But it depends on how much they are worth to you. I sold my Volk SF Challenge set (17x9+22) for less with near-new tyres!
Well I would live some rays te37s but waaay out of my price range haha..
Maybe one day.
Rough price on 32 GTR wheels with or without tyres? In your opinion :)
    • It might be fine. I was just saying that I wouldn't trust it without testing it.
    • Traction wasn't bad, l couldn't give it everything off the line but was able to go WOT about half a second after rolling - good for NZ drag strips.   Like one run I did a 1.96 60ft and pretty sure I was on for a 12.4 but lifted early as I was on a 12.5 dial in, and still won haha
    • Nice one! I was going to take mine down to SMSP drags one Weds night. I'd love to compare it with my GTR which did a 12.3. The bum-dyno in the 335i says its quicker.   How was the traction @Lithium?
    • AFAIK I've seen other people recommend using the back of the balance tube as well. Andre Simon from HPA at least. I can't imagine it being that far off from ideal even if it was only used to drive a boost gauge from the factory.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
