****parting Out Rb25det Series 2**** + Tomei + Osg Clutch
8znR33
 Share
I have another post in regards to selling this engine as a whole, but cant be bothered waiting now so im just gonna start parting it out now, still wiilling to sell the engine as a whole if anyone interested but heres the list.
(the head is still attached to the block but will take apart if there are buyers for it otherwise ill keep it together until it does get sold)
If my prices are unjust just throw me an offer and we'll see, but no low balling offers plz, will post some parts and maybe larger items if u organise the courier.
Head incl: complete except for the bolts holding in the rocker covers, also missing the bolt that holds the vct bit on the intake cam gear. $400
Block: Pistons still in just needs head if you are not buying the head i have no pumps, has water pump and water pump, i knw the water pump is still in vgc, havent taken oil pump yet but should be fine to use again. $500
Power steering pump with bracket: vgc no problems. $50
Alternators x2: ones an rb30 one is bit dirty, both work fine. $100 each
stock exh manifold: vgc $50
Intake plenum + runners + throttle body +tps series 2: vgc comes with bolts and gaskt for it. $110
Tomei metal head gasket: brand new 87mm and 1.2mm thick. $400
OS giken / Cusco super single clutch: roughly 75-85% meat left on it the plates look fine was running great on the car b4 taking it off. $600 ono
So far thats all i can think of if i think of anything else ill add it later or just ask me wat u want i might have it.
Pm or txt to my mob 0414424902
Cheers
Lok
Edited by 8znR33
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
