Hi guys my R34 is due for its 100k service and I was wondering if people knew any good places in and around Melbourne to take it to get it done?
I got a quote from Nissan in Bundoora and they said it would be ~ $950, but that was without the water pump, which they said they would inspect and replace only if it was leaking.
Thanks in advance!
Edited by vatchuthan
https://www.sau.com.au/forums/topic/316654-performace-centers-in-melbourne/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
