I bought one of those syphoning hoses with the jiggly ball at the end that u stick in the tank through the filler and jiggle (rather than suck on the hose) but it stops about half a metre in, i'm guessing there's some sort of protection mesh in there to stop junk from falling in to the fuel tank by accident. So the hose is out..
I've read that the fuel pump can do the job by simply unhooking one of the fuel lines and turning the key to the ON position and let the fuel pump spit it all out. But where do I unhook the fuel line ?
It's an R34 GTT .. I can see the fuel line on the left hand side coming into the fuel filter .. do I disconnect it before the fuel filter or after and if so where ? Cheers
Oh yeah ..car's been sitting in the garage for 6 months with half a tank of ultimate ..something stinks really putrid, I hope its just the fuel and not some small animal that made a home in there somewhere, lived a happy life and then DIED.
https://www.sau.com.au/forums/topic/316680-how-to-get-old-fuel-out-of-car/
ok i've unplugged the fuel line on the fuel rail (just after the filter) and when switching the key to ON I can hear the fuel pump priming and it squirts about 50ml of fuel then stops
At that rate I will have to switch on/off about 500 times which i'm sure would kill my fuel pump and battery and take ages .. Is there any way to get the fuel pump to keep sending fuel without stopping ???
I'm about to take the fuel filter off and see if it keeps flowing without the fuel filter on the line but somehow I doubt it ANYONE ?!?
Not 100% on this...is the fuel pump actually located in the tank in the 34 or remote..
Maybe access the fuel pump, from the boot area (under the step in the boot luggage area ) and u might be able to use the pump that u got that way...
just throwing it out there.. may or maynot work?!!?!?!
Correcto!
Just short the pump. Don't let it run dry for too long though, because they tend to depend on fuel for lubication of the pump :D
How do you short the fuel pump though ? I've already searched for "short the fuel pump skyline" and whatnot earlier today on teh google but came up with nothing useful
hm come to think of it I do have that nissan consult cable and some software somewhere ..wonder if any of those programs can be used to make the fuel pump run at full speed to empty the tank
edit: yep looks like NIssan Datascan which I bought last year has a 'fuel pump' active test so that should do the trick ..will report tommorow
those jiggle syphon hoses are a bit of a pain. a much better setup to use is a boat fuel line setup. they have the bulb in the middle of them that you squeeze to such the fuel though.
also while you can use the fuel pump, it may take a while to do so. depending on how much of a hurry you are in it may be quicker to remove the panel in the boot where you access the fuel pump through and just syphon it out through there. it is a bit more fiddly to do but you will be able to syphon the fuel out quicker. but thinking about it, the extra prep time probably outweighs the gains from faster syphoning.
i usually just pull the cas out of the car and rotate it by hand, this will keep the pump on, dont fun it flat out without giving it a break. you will then have to retime the engine or use the marks that you should have written on it, however they are not always 100%accurate
What are you going to do with the fuel once you get it out of the fuel tank?
Frankly I wouldn't be worrying about it. The fuel will still run the engine. Once you get the car out of the garage, the smell should dissipate (if it is just the fuel).
^^^ yep or just get some more Ultimate in a can and pour it into the tank if you're concerned about starting it and then driving it to the servo to dilute the sulphur smell/effects.
Sulphur can vary in its %age by up to 100%
http://www.kittiwake.com/4_7_sulphur.com and yes, I'm aware that %ages can vary quite a bit from country to country as well as between brands - or even batches within brands.
Edit: lets's try that again... http://www.kittiwake.com/4_7_sulphur.htm
datascan couldnt do it ..same issue as switching ignition to ON ie. only pumps a small amount then stops.
I used Yavuz's (unigroup) suggestion which was to have the fuel return hose disconnected and run into a container .. start the car and run it until its out of fuel. Took about 10 mins with half a tank. Easy as :D I'm hoping the fuel filter picked up any nasty crap before it could clog my injectors.
Anyway, fresh BPU in there and the car drove without any issues.
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
Ɨ
Ɨ
