Hi, guys
My clutch itself is functioning perfectly, but the pedal requires me to push my foot right to the floor before the clutch engages. It's also got a creaky pedal sound, i don't know if that's related.
I've been quoted $100 for a replacement pedal box, and 4 hours labor to install it. I'm very poor at the moment, so thought I'd give it a go myself before giving up and sending the car to them.
I've done searches but can't find any tutorial or useful information. Can anybody point me in the right direction for replacing the clutch pedal box on a R33 GTS-T?
https://www.sau.com.au/forums/topic/316682-how-to-swap-pedal-box/
Have the spot welds on the clutch pedal box snapped? I took mine out and rewelded it. Took me like 20/30 mins to take it out the first time. It's way to easy. Grad a torch and look under there, you will be surprised how easy it is!
Hi, guys
easy job.
you don't need to take out the whole dash, just push the seat back as far as you can and you should have no issue undoing the bolts and replacing it
I don't know what you are saying, but i'm happy to check it out if you can explain it to me?
hey man ,
i just had the exact same problem , became so bad i almost had to put my foot through the floor!!! the pedal box is cracked and most likely wont last longer than a couple of months , i was freakin out too thinkin it was gonna be $600 - $700 ( as was quoted ) to fix , turns out its 3 bolts under the master cylinder and a bit of tetris action to remove ( and worse to get back in ) and a pin that runs through the box and the pedal , and boom drops straight out , a bit of welding and strengthening around the weak spots ( mine had 6 cracks and fractures ) , seriously took about 45 minutes of actual work!!!! think about it , so worth it !!!!
i payed the princely sum of.........NUTHING!!!!!!
feels like a button clutch should !!!!! beta than ever!!! STRONGER THAN NISMO ITEM!!!!
enjoy!!!
dspec2, i'd especially love your help on this, can you mark out exactly what you mean?
I have a very mechanically minded friend, and we'd love to tackle this together.
Alternatively, I'd love anybody to show me the bits that need replacing/welding, whatever, just take my pics and draw all over them if you wish :D
Sorry if they are crap quality, it's 12:30 at night so theres not alot of light around at the moment :D
if it creaking its probably cracked and flexing, common problem.
So which bit needs to be replaced?
I'm just trying to work out what needs to be done, i figured that if i worked out how to install a turbo by myself, i should be able to do this, i just don't know where to start :)
Can you link me to a tutorial or information, or point out on those pictures, which part needs to be fixed?
Thanks guys!
this is the clutch pedal out of my 32. the spot welds im pointing to are possibly broken on yours. its bolted in three spots, 2 bolts go through your firewall and hold the clutch master on, the third is under the dash you can get to it with a 3/8 rachet small extension an 12mm socket. there is also a clevis pin that is in the pedal that you will need to pull out, its for your master cylinder rod. once the box is out you can either TIG or MIG weld it or buy a 2nd hand unit, or if your prepared to wait a few days get a nismo one from nengun or other supplier
pedalbox.pdf
Edited by turboedsloth
Alright,
I removed the pedal box as per instructions, probably took about half an hour, was done exactly as described: remove 2 clutch master cylinder bolts, remove the pin from the pedal (connecting it to master cylinder), and one final bolt u can get to with a few socket extensions, right above the clutch pedal springs :(
Anyway, now that it's removed, I can't see any problem with it, can you guys take a look and let me know what you think?
Basically, the clutch pedal squeaks (which i guess is tolerable, what lube would u guys recommend), but the main problem was that the "friction point" of the clutch was pretty much at the floor, so i had to put my foot almost through the firewall to change gears, it's totally driveable though, just alot more work than it should be.
Heres the pics, I didn't know what angle was best, so thought i'd give you 7 :( If you want a different angle, just let me know and i'll go take a pic.
I'd love to get this sorted, as I can't get too far without a clutch pedal :(
Hey bud,
As far as i can remember Skylines have a hydraulically adjusting clutch. So they should compensate for the wear in the clutch.
But you can adjust the "friction" point of the clutch by adjusting the rod that connects the pedal to the master cylinder.
Just dont get to carried away and adjust it to beyond the point for the clutch fluid to be able to release pressure into the master cylinder reservoir as it gets hot.
If its biting on the floor you should adjust the master cylinder rod out....or towards the rear of the car. I believe that is the right way....but someone can correct me if im wrong.
You can also adjust the resting point of the clutch.....but again you want to keep the pedals pretty much in line. But there may be room to move a little there.
Cheers
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
