Adobe Photoshop CS 8.0 ???????
Guest RedLineGTR
Does anyone have Adobe Photoshop CS 8.0 ????? yet???
If so does anyone have any problems with the keyboard shortcuts??
Eg. Ctrl+O is meant to work only works in Imageready but not photoshop the keyboard settings menu is set to how it is when it was first installed so no idea what the problem is??
Can anyone help out??
Cheers Rob :wassup:
https://www.sau.com.au/forums/topic/31670-adobe-photoshop-cs-80/
