I've got an R33 GTST spec 1, and I'm running into some troubles very recently... hopefully somebody can help me :D
This is the problem I'm having:
When at full boost in lower revs (up to about 4500rpm), my air/fuel ratio is 10.9... pretty rich already.
But when around 4500-ish rpm, it goes down to 10.0, and the screen blinks (meaning it is running even richer than that 10gr of air per gram of fuel it can display).
This feels like a bit of a flat spot, like the one people seem to have after installing a FMIC (mine is running so rich, I prob. could get away with one).
It's idling just a tiny bit rough, but it has done so since I've bought the car.
I have not changed anything on the car recently that could cause this problem.
This is the speclist (engine wise), most parts are less than 1 year old:
- RB25DET, completely stock engine, m/t
- stock ECU
- stock T28 turbo (ceramic turbine wheel, steel compressor wheel)
- stock after-turbo elbow
- removed carbon cannister
*all else, if not mentioned, stock*
- Bullet Exhaust 3" stainless steel downpipe
- Autobahn88 3" stainless steel testpipe (OE egt sensor installed after trimming some of the thread of from the decat)
- Invidia/RS*R 3" stainless steel catback
- Apex'i pod filter
- NXS Motorsports manual boost controller (set at 10psi firm)
- customised OE spark plug cover (ventilated to keep the coilpacks cooler)
- large capacity fuel filter
- new Gates fuel hoses in engine compartment and fuel tank
- Walbro 255lph in-tank fuel pump
- fuel pump direct 12+ volt feed from battery (loom powers relais, 11,5v max)
- HKS SSQV mkI blow-off valve
- Splitfire coilpacks
- NGK 'Iridium IX' spark plugs, grade 7 with 1.1mm gap (BKR7EIX, changed january or february)
- Apex Performance aluminium radiator and 1.1bar cap
- twin 12" slim fans
- DIF dual fan control unit
- 76°C thermostat
This is what I've tried:
- resoldered the afm's internals
- ECU reset
- air filter cleaned
- replaced most (if not all) vacuum lines and fuel hoses
- checked for leaks in piping after the afm (there were none)
- I always use RON98 fuel
- I've read the 'stop your hesitation' topic here, but it is about running lean, not rich... I could try to check the tps though...
This is what I'd like to know:
What could be the cause of it running só rich?
What can I try to stop it?
And another question, as it might be part of the problem:
When driving on the motorway, my afr is around 12.0-12.4... is that normal?
what are you using to measure the AFR? is it a wideband gauge and wideband sensor? or normal guage and piggybacking off the ECU 02 signal?
it's the stock ecu, its designed to do that, get a piggyback or standalone ECU and tune it correctly
and the standard turbo isn't T28 and it isn't steel wheel
I've got an R33 GTST spec 1, and I'm running into some troubles very recently... hopefully somebody can help me :)
- stock ECU
- Apex'i pod filter
- 76°C thermostat
- ECU reset
hey, just would like to know if your fuel lines are bigger than stock? but the fuel mods you have seems to bump ur fuel pressure up. do you have a FPR? if not get one and turn it down a bit.
no dont bother with the fuel pressure reg, it's not required
your AFR's are mega rich as it's the stock ECU trying to run as rich as possible on full load (it's designed to) and cruise around 12 AFR
I have a Prosport wideband controller set with a Bosch LSU 4.9 sensor.
This is the set I have; http://prosportgauges.com/wideband-air-fuel-ratio-kit.aspx
No n00bie stuff like getting afr from a narrowband here :)
And I've read this multiple times before on different forums; the stock RB25DET turbo is a T28 with journal bearings, a water jacket, a ceramic turbine wheel and a steel compressor wheel... spec2 is the same but has has a teflon comp. wheel afaik.
Not right then?
12 afr is crazy... should be at least 14 to 1, best would be 14.7 to 1, and I'm not even daring to talk about lean burn tech because tuning is not my specialty.
No wonder stock Skylines make a full tank of petrol last for 300km or so.
Enough for the off-topic hehe :down:
'As rich as possible', I don't know about that... I was told afr should be around 11.5 to 12.0 under full boost, so 10.9 is rich... my cylinder walls must have a mirror polish by now (bore wash), even though it doesn't use a drop of oil.
It used to just sit at 10.9 at full boost, wich is rich, but it didn't dump in fuel like it does now.
What I don't get is why it does that... any idea?
No, they're 8mm, wich is stock.
The fpr is also stock, so even when I ad two more fuel pumps, my fuel pressure would still the same.
what boost are you running?
standard 33 ECUs run megga rich as Paul said...more so when running higher than standard boost.
Maybe pull some boost out of it, but 10:1 is about normal for a 33 gtst
I've set the boost controller at 10psi firm... stock is 8psi?
Hello from Germany,
I have the same problem since some days. My car was mapped 2 months ago and was running fine. Now it is going rich when boost comes up. The wideband-AFR (AEM) shows the ratio about 10 and there is no power any more. From the beginning to the (under) half throttle position the AFR is normal.
I have the idea, that the intake pipes are leaky, maybe where the bov is fixed on (GREDDY Type S) - but have to check. Will check the fuel pressure regulator too..
cheers
vik
get a piggyback or standalone, run 12psi and youll make more average power everywhere, get better fuel economy and it will overall be heaps quicker
you'll need a bigger intercooler as well
Mate it's just the stock ECU doing what it does - protecting the motor. Nice and simple really.
You are hitting the limits of the stock ECU where it goes into R&R mode (Rich & Retard) which causes the AFR's to become ridiculously rich.
Having a ATMO BOV is doing you no favours either. They are well known to cause overfuelling.
Get a proper ECU/tune and problem solved.
Also check the fuel pressure as others have stated, but i doubt the factory reg has failed because if it did you would have massive clouds of fuel behind the car when giving it a good boot. I know thats certainly what mine did when the fuel reg spat the dummy
Hello from Germany,
cheers
vik
Your car actually loses loads of power?
Mine doesn't feel like that, it's notable, but it just keeps going on.
True, and I've tried fitting one, but a large intercooler doesn't fit between the side markers in my front bumper (stock Type M) :)
I've replaced the HKS bov with the stock recirc valve and pipe, but it didn't make any difference (other than it didn't seem to be as responsive, nor spool as quick as with the HKS).
I do need another EMS, I agree... but I'll just turn the boost down for now, to 8psi, and see what it does to the afr.
I was thinking about getting a Link or Vipec plug-n-play ECU, but I'd also like to sell the car (I'd really like a GTR), so it would be best for my wallet to leave it as is as much as possible, but I don't want to sell a 'faulty' car.
I was talking about the 'fix your hesitation' topic before... just realized it's on GTRcanada.com, not here... so here is a link to what I meant;
http://forums.gtrcanada.com/gts-tech/t-fix...tion-26010.html
HEKT1K;
10.7 is hella rich already, too rich and the excess gas washes away the oilfilm from the hone... thus polishing it, causing blow by and oil consumption.
Thats normal for a stock ecu to dump shit loads of fuel to protect the motor.
If u turn down the boost it wouldn't be that bad.... but what the hell!!!...... its ok once its not hitting r&r
I actually put on an adj reg on there to drop the fuel pressure along with an safc2 and it was much better
As for it being rich at idle that would be your o2 sensor
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
