I recently purchased a GCG r33 high flow turbo. I took it to GCG and had it inspected . While i was there i spoke to michael and he informs me that this turbo can handle 20psi, make 250kw on rb25 and also boost 400rpm later than the original turbo.
my mods include
3inch exhaust with dump pipe
PFC
Standard airbox with high flow filter
FMIC
040 fuel pump
Z32 air flow on its way
555cc injectors on its way
Yavuc from Unigroup will be tuning
I have upgraded the r33 wastegate 7psi with the r32 10psi wastegate as these are stronger. i have heard that GCG HF spikes at 18psi then drops to 16psi. Hopefully i have eliminated this with a stronger waste gate.
Is the r33 rear turbine housing causing this issue due to the size?
Does the r34 op6 housing eliminate this issue and allow higher boost?
Will i hit 250kwatw with the above mods?
Any advice or experience greatly appreciated, thankyou
the highflow will make 250rwkw easily
if you want to run 16psi all the time, dont fit a 10psi actuator and let your boost controller bleed the difference, you should fit a larger actuator say 14psi and let your controller bleed 2psi
the bigger the difference between the actuator and the target boost you want, the harder your contrller has to work and the more difficult it would be to maintain stable control
I have a greedy profec 2 boost controler. I want my target boost to be 18psi and holding strongly to 7000rpm.
Wouldnt i be better off running Rb20 wastegate(10psi spring) rather than Rb25 wastegate(7psi) spring if i want to hold 18psi on high boost setting. The controler will not work as hard as you say..
I already have both wastegates and im tossing up wether to buy another wastegate say 12psi or maybe 14psi aftermarket . My aim is to hold boost levels strong and consistant as i have heard that the high flows cannot flow 18psi without dropping to 16psi. Also why the GCG turbos retain the standard rb25 7 psi wastegate, shouldnt they be upgraded like hypergear turbos and hks turbos etc.
as stated, get the spring rated closest to the pressure you want to run
i dont know why GCG do that, go and ask them ?
logic says it comes in as a normal turbo, they hiflow it and it's done, if you want a higher rated spring you ask for it and they charge extra
on my old R33 i ran a GCG highflow, was running 20psi boost that would then taper off to 18psi higher in the rev range. Great turbos and sensational value for money, i loved it. I was running a Profec B Spec II as well with PFC and all other supporting mods. Made 253rwkw, my tuner said it could have made a fair bit more but i didnt want to push it too much.
Thanks for the feedback, you have inspired some new confidence in achieving my desired results, well done. If i can achieve the same results i will be a happy man.
Did your high flow retain the standard wastegate or did it have an aftermarket wastegate.
How was the response of the turbo? compared to the other bolt on options for r33 .
The R32 10psi actuator will be fine. I've got the R33 gcg with R32 actuator running about 18psi with a simple boost controller (ball and spring), tapers back to 16psi in last 1000rpm I think...electronic boost controller could maintain the 18psi to redline but I'm not worried.
What they do as an option on the turbos is bore our the wastegate opening and add a larger "flap" to improve boost control.
Should be fine with or without though I would think.
Pretty sure mine had the stock actuator on it. The response form the turbo was sensational, really good mid-top range with a huge whack at the top (for a small turbo). I was extremely happy with it and you cant complain for the price, great bang for bucks. Throttle Response was almost identical to stock, it takes a fraction longer to boost up to the full 20psi, just dont expect to floor it and WHAM instant 20psi, but after driving several other modified turbo cars and modded skylines i didnt even notice it after a few days. Having said that its still super responsive for street driving, which is why i had the GCG as most streets around me are 50km/hr zones so i didnt want any form of lag. Was very happy with it, and you will be too. GCG have a tip top reputation, and the reason i bought their high flow is many manyexperienced forum members couldnt say a bad word about them. So all in all thats my 2 cents and experience with those turbos.
ENJOY!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
