What a world we live in.... ....
A few weeks ago in a movie theatre in Melbourne a person sat on something that was poking out of one of the seats.
When she got up to see what it was she found a needle sticking out Of the seat with a note attached saying a quote; 'You have just been infected by HIV' quote..
The Disease control Centre in Melbourne reports many similar incidents have occurred in many other Australian cities recently.
All tested needles are HIV Positive.
The Centre also reports that needles have been found in the cash dispensers in ATMs. We ask everyone to use extreme caution when faced with this kind of situation. All public chairs/seats should be inspected with vigilance and caution before use.
17 people have been tested positive in the Western suburbs alone in the last 2 months!!! A careful visual inspection should be enough.
In addition they ask that each of you pass this message along to all members of your family and your friends of the potential danger. We all have to be careful at public places! This is very important.
Just think about saving a life of someone even you don't know by forwarding this message. Please, take a few seconds of your time to pass it along.
Australian Red Cross Blood Service
I hope this is a hoax.
https://www.sau.com.au/forums/topic/316776-seriously-like-what-the-fck/
http://www.hoax-slayer.com/hiv-needle-hoax.html
but i know of a guy i used to work with, he lives in st kilda
he opened his mailbox to find a needle in there and he pricked himself
he was ok after tests, but still not pretty and very scary for him
relax guys... its just another hoax :)
  Quote
Blood Service response to HIV needle hoax
10.2.2010A recent hoax email has been circulating throughout Melbourne's Yarra Trams employees. The email claims to be about someone who supposedly gets HIV from sitting on a needle in a cinema.
This is Australian Red Cross Blood Service's official response, drafted by National Communications.
"The Australian Red Cross Blood Service is aware of an email in circulation warning people about a HIV-infected needle found in a cinema. Although the message appears to have been transmitted through the ARCBS email system, it was NOT an official transmission. It appears the HIV warning email is a hoax, similar to those publicised through the urban legends website. Apparently the hoax email has been circulating since 1998, but the location changes as it is forwarded."
from here
Straight from Snopes
http://www.snopes.com/horrors/mayhem/payphone.asp
'HIV lives only a short time outside of its host medium. Contact with an HIV-contaminated needle would have to occur while the conamination was still fresh to present a danger of infection.'
Could tell it was a hoax before those websites, just have to look at the spelling/grammar mistakes in the "official" release lol. Why someone would do this as a hoax I have no idea, it's not like you can see peoples reactions.
I believe AIDS doesnt survive very long outside the body so contracting it is unlikely. Realistically you are much more likely to contract hepatitus, which can survive outside the body for days and is very very common among junkies, so I'm still cautious about needles in public places, especially in places junkies might hang around. About 5 years ago I nearly got pricked by a used needle that had been stuck up into the paper towel dispenser in a public toilet.
lay off the crack you fox.
not to scare you guys....but there is something similar to this that is going on......
If a guy comes to your door (dressed like a sales person/mormon) and asks to see the top you are wearing, do not remove and show him - he only wants to see your nipples. Happened to a friend of mine...boy did he feel violated........i repeat, do not show him your nipples....
just a warning......
LMAO
it was you wasnt it..... not your so called "friend"
:D
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
