very pset atm, it seems that my lifters are getting flat spots they are very noisy!!! My car doesnt even have 100k on it yet! Has any one ever had worn out lifters on their 34? If so what is the most inexpensive path to take? Also my coil packs are gone and now my clutch is going!!!!!
https://www.sau.com.au/forums/topic/316787-r34-lifters/
oil level looks fine, i have started getting the problem after i put in an oil cooler?? Could the oil cooler take away too much oil and starve the head of oil?
make sure the lines are round the right way (correct oil flow). In all my years i have never had issue with worn lifters in R34, but i see the cooler installed wrong all the time.
the centre hole with thread is return the outside hole is output.
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5181844
+1 indeed
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5181876
went and sought some advice from a trusted and experienced skyline specialist in melbourne they are doumbfounded as well by the noise it is making....BUT they did notice quite a strong dint in the oil sump. They are thinking that the knock may have been hard enough to damage the sender = lack of oil to head, this is backed up by the fack my motul 300v has bubbles in it, any thoughts people?? im getting real nervous
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5182651
Sounds like you got some issues mate. Frothing of oil is exremely bad.
Was the dent in the sump before the cooler went on? If so, why the problems now?
General rule of thumb is if you change something and then a problem occurs, look to what you just changed
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5182803
maybe cracked oil pickup. Hard to tell without having the car to do some tests. Did the shop think the dent was big enough to contact the pickup? if so drop the sump asap and at least check it over..
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5183227
performance shop i went to are under the impression that the sump can not be removed easily, need to take out the engine? big dollars for that
its not hard. Drop the front crossmember. the engine just needs to be supported from above with something like a engine brace. We have done in chassis rebuilds this way. In and out in half a day.
In fact we did wheezys (sau nic) car this way.
use one of these to support engine.
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5183915
something new.....when i first start the car there is NO TICKING. it takes some slight throttle for the ticking to start?? WTF IS HAPPENING??
First of all you need to STOP running the car for starters, because you’re probably causing irreversible damage by continuing to run/drive it. Find the source of the issue, don't muck around when it comes to oil pressure problems.
Then drop the sump and find out what's happening with the pick-up. If the sump had a dint before, and all you have done is installed the cooler, then is sounds like you haven't added additional oil to accommodate the cooler. I personally would be checking the pick-up anyway just to be safe.
You can't just wack the cooler on, it will simply pump oil into the cooler/lines and the sump will end up with nothing in it, or very low, hence the ticking progression with throttle.
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5187636
hi james , thanks for that info but cooler has been installed by a very trusted mechanic, specialises in track cars so im hoping he considered this. Also my oil level is fine and oil pressure in the block is fine so i dont think it would be due to lack of oil which still does not explain the bubbles in the oil. But i agree the less driven the better and im taking it in tommorow to attach a pressure gauge to the head and check oil pressure in the head, if that is low then we will check oil pickup.
  • Nope 1
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5188111
I am unsure who you have been talking to but I don't know how you are going to do a 'pressure' test on the cylinder head when it is splash lubricated.
I hope you are going to be getting it towed to the workshop also. Any driving will possibly ruin it.
The frothing of the oil is usually caused when the oil lines are arse about.
You want to make sure you ask the workshop very specific questions if the engine is cactus. If they have fitted it incorrectly then they are liable for any damages. If they did fit it correctly then there has to be another reason.
If they are still unsure of what the noise is and everything is fitted correctly, then take a GOOD video of the noise and post it. I should be able to tell you what it is.
Also, if the ticking noise comes only once revved, then it's most likely not going to be lifters
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5188888
We just finished rebuilding a rb26 for an SAU member... a reputable workshop fitted the oil filter relocator lines ass about...... every shop can make mistakes dont take anything for granted best bet is to check the line routing.
https://www.sau.com.au/forums/topic/316787-r34-lifters/#findComment-5189182
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
