Firstly.. this should probably in one of the technical forums.
Secondly it depends which brand alternator is in your car. Your local nissan dealer should be able to point you in the right direction, otherwise take it to an auto electricians until one doesn't say 'you can't service these' :ninja:. I was lucky enough to stumble upon an auto elec near by who regularly services the local nissan dealers cars. 40 dollars and 2 hours or so turn around from memory.
Also it might be worth pointing out that if you are going to do any work on it.. it is probably worth getting it tested first. Bearings also have a habit of getting tired in these.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
