  • Replies 40
i read a post on the zed forums about suspension setup for drags (by a guy who ran 10.95 with stock turbos and engine) who said to run stock shocks/springs on the front and put higher damping on the rear since when the rear squats it induces negative camber and toe (it has something to do with the IRS and antisquat geometry, i am not too sure exactly) which reduces your tyre contact area. i had always though soft rear was best for drags but pretty much every other zed guy i have spoken to has said the same thing as this guy and said they ran better times that way. i figured r32 and z32 may have similar rear suspension setup.
anyway back on topic, yes you should go to calder ric. i would like to race again but the clutch did not like 4500rpm launches and it was still bogging down so need to upgrade clutch before I go again.
Just chuck a turbo back exhaust on it i recon, the rims are ok, maybe a pod / larger fmic if needed? and up the boost a bit for the drags.. would be nice :D
Do you have semi slicks / slicks for your r32? i assume so by looking at your sig
Yeah I run semi's on the 32 for circuit work.
It's quite suprising but standard exhaust is good for 320rwkw's apparently. Cat would probably have to change I imagine.
Sandeep. Drags is all about weight transfer but if that weight transfer causes negative camber then that's a problem. Standard susp is pretty good for 1/4 mile stuff.
I Highly doubt that!
Exactly why you don't listen to everything you read on the forums...get your rear geometry right to account for some of the negative camber on the squat and have soft rears to get the weight transfer towards the back...a zed is a car like any other...the laws of physics still apply to it...
Baha some of the stuff on the zed forums is bloody funny to read :)
Yes softer is better as prevously mentioned, and if you have adjustable UCAs, running positive camber is the way to go to account for dynamic camber on squat.
I cant wait to put some softer springs in and slide some slicks on, try and hit the 10 bracket :P
Yeah man. Is yours auto or man?
I ended up with the auto. I wanted a manual but after taking an auto for a test drive just for comparisons sake, I was hooked. They are so damn good!
Did you try using the launch control at all?
Yeah launch control every time. holds 3600 rpm.
Even though it's known as a launch control it's more of a static rev limit coz when you go over 10kph it disengages and you wheel spin starts. At calder I didn't have much of an issue with wheel spin coz it's pretty grippy.
Ah yeah, I wasn't too sure on how it worked. Auto ones don't have LC. They just get a nice crackle throught the exhaust when you change gears. It's rather addictive actually :)
Definatly keen on taking it down to the next meet. A stock auto one running high 12's is very encouraging.
What the Fuck?!
I assume they are talking about a Z32..?
A stock Z32 can run a 10.95 with modified rear suspension?
I would like to see the quarter mile time sheet.
stock unopened engine and turbos but more boost, tuned + bolt on mods. did some more reading and turns out he was running 80 shot of Nos too which i didn't know before. still an impressive time though, best stock turbo/stock engine zed i can find in australia is high 11's without nos. and yeah have been doing more reading and all the guys who drag zeds say to run stiffer on the rear. i think it is more due to the design of the irs on the zed which is not suited to drag racing, not just camber on squat like femno said but also toe changes. and yeah as limpus said you can change the mounting points for the control arms to fix this, which is what UAS have been doing, but pretty expensive so I guess this is why everyone just ups the damping on the rear.
What the Fuck?!
I see...
The VG30DETT had more potential then I thought.
Well at least you cleared that up :)
LOL! @ NOS.
You don't need that Sandeep.
Hey buddy,
Good to see you have tried the XR6 at Calder, I have a manual FG XR6 Turbo ute as well, the launch control is sooo good but I am having the same problem as you. It launches really well but as soon as it gets going it starts to spin the wheels in the mid rpm range.
Even second gear is a little tail happy unless you ease it into gear.
Hey buddy,
Haha. So many FG's! post up a pic
this is mine.
I love the colour!
They are all good colours! The lux pack 19's are nice too but I couldn't justify the extra considering I would probably change em anyway.
Where did you get yours? Strapp ford? Our number plates are only 6 numbers apart!
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
    • With my block out to get honed, I'm just prepping all my auxiliary components in my mean time. I took my oil pump apart to inspect and repack it with assembly lube and either haven't noticed this in the past or found my answer and can't remember. What exactly is the regulator washer that the manual mentions replacing? I don't have one and from the manual it seems to seal the regulator plug to the housing but I can't see it on any pictures of new pumps either. Can anyone fill me in? I'm presuming this was phased out as I also can't find a replacement part in epc.    Image of a new pump. Can't see a washer there either.
    • Of course, it's a money making for profit organisation. Building/Contents insurers in QLD having a field trip.  High fives, and bonuses for all the SLT.
    • The idea is that this gives all the benefits of ITB's and Trumpets with zero downsides of ITB's and Trumpets
