You need to disable the blow off valve so that it cant release the air. You dont need any specific type of pipe, but a metal pipe with a pod will give the loudest dose. Theres a huge thread on a vl forum about the different shaped intake pipes and what type of noise they make BAHAHAHAHAHA!
Unfortunately though I dont know how to disable the blow off valve as I am new to skylines.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184165
cool.. i kno how to disable the bov and add metal pipe... just not sure on what to do with the hoses once i remove the standard intake pipe..
any help would be useful...
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184198
Pff, everyone keeps repeating that crap about turbo chatter, 'dose' and compressor surge. People blow up their turbos by putting more boost into it, there still isn't any proof 'dose' has wrecked any turbos. Sure, in theory, engineering/mechanics wise, it should wear it more, but no more than a few % and far less than abusing it with high boost etc.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184234
Sort of depends on how much damage your willing to accept then.
There should be a way to quantify exactly how much the reversion slows the wheel down, but it probably wouldnt mean much unless you could whack it on a dyno for back to back comparisons.
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184276
unbolt your stock BOV, trace it out on a rubber matt or plastic or aluminium, punch out 2x holes for the bolts, bolt back everything.. looks stock, flutters like a the sphincter of the universe :D
I did that when my stock BOV couldn't handle the boost but it got annoying so I replaced it with an aftermarket plumb back.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184297
It's called search, use it:
Dose pipe: http://www.skylinesaustralia.com/forums/se...te=%2Bdose+pipe
Hektik flutter: http://www.skylinesaustralia.com/forums/se...Bhektik+flutter
VL uleh: http://www.skylinesaustralia.com/forums/se...lite=%2Bvl+uleh
Sick flutter: http://www.skylinesaustralia.com/forums/se...%2Bsick+flutter
Seriously, it aint hard. Justy type in an adjective describing what you want "sick, hektik, fully, awesome, mad" and then an adjective describing the noise "flutter, dose, pidgeon, zututu" and you will find a billion threads.
*Sigh*
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184302
One will be BOV return. Don't need this when dosing.
Other will be breather return from cam covers. Either get a catch-can or put a fitting in your metal intake pipe for that hose to push onto...
could i just leave it....????? technically it wouldnt be going any where anyway.. would it..???????
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184372
No because it will be a vacuum leak since from factory one side goes to the plenum the other into that intake pipe (not to mention if you just left it open oil could drip out onto the exhaust manifold and start a fire). So either block the right side off or get a catch can or plumb it into your new pipe.
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184380
*Sigh*
love your work...awesome.
on topic...why you would want to do such a thing is beyond me. Sorry Mr Cosgriff :)
Edited by Swiper the Fox
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184539
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
