Hiya,
Superlap needs volunteers to help out with the 2010 World Time Attack Challenge!
Are you a motorsport enthusiast with some track experience? Sign up for the Superlap Volunteer Program and see the world’s biggest time attack for free!
That’s not all, for your help during the event we’ll provide you with the official World Time Attack gear and an unrestricted access to the whole track and our corporate suite. We’ll also throw in a full merchandise pack and lunch to boot!
This is a unique opportunity to be a part of the 2010 World Time Attack Challenge and participate in the biggest event of its kind in the world!
Superlap Link Click On Me!!!!!
If you have any questions please let me know!!
Thanks Jess
https://www.sau.com.au/forums/topic/316989-superlap-volunteers-2010/
Hey,
I'll be happy to help in anyway needed, I have Zero track expeirence but I can basically do anything you need me to, to make the day an awsome experince for all involved. If you guys would like help on a bbq or something like that no worries
Justin.
Ive worked nearly 3 years at mcdonalds, completed certificate 2 in Retail Management, I understand cars and OHS and currently doing Cert 3, I know it's sounding like a Job application but I really want to be able to help at the day, so just to prove i'm not talking S***.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
