Hi all,
as the title says, I´ve been a member here for a very long time. Actually even before I bought my BNR34 back in the autumn of 2003. That one is sold and I´ve also gone through a BCNR33 since back then. At the moment I have a R35 GT-R which is my shops democar. I run a company in Sweden called APP and we´ve specialized ourselfs in the R35 GT-R since it came out here last summer. At the moment I´m looking for some parts for a special project of ours so if you can help, I´d very much appreciate it. Please take a look in the V-series section for the thread.
Best regards,
Perra
https://www.sau.com.au/forums/topic/317005-old-member-time-to-start-posting/
Hehe.... Perra!!!
You'd have to take 1st prize for the least number of posts per year!!!!!!
Perhaps you're too busy in your work?
The last time I was in Stockholm, Ford had just taken over Volvo (and now it's Chinese) + SAAB still existed as a car company.
In 2004, I did a cruise from Copenhagen > Stockholm > Helsinki > St Petersburg > Tallin > Gdansk then back to Vienna > The Med
Stockholm is a beautiful city on a stack of islands (for our readers).
Cheers, Terry
Hehe.... Perra!!!
Cheers, Terry
I know! I actually had to check how many posts I had before writing that post. Turns out it was a big fat 0! :( :(
Yes, I´m actually very busy and have been for a long time. I´m trying to keep up on the Swedish, UK and American forums mostly. I really don´t have enough time to do more than the occasional look over here.
If you ever come back to Sweden, send me a mail and we can get together for a beer. :(
/Perra
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
