i changed the ecu with the auto one now i have power and reds on thr dash but car kranks but wont start now i think it might have something to do with neutral switch does anyone no where to bridge this or what is stopping it from starting???
also i have had a thought that when the clutch fan ceased could it have caused some error code not sure which one but maybe this is what causeing my timing retarding i have since reset it and diagnosed it so hopefuly it comes good
Sound like your clutch is slipping.
If what you said in the first post i correct - gets to 5k Rpm then just starts dead revving - thats the clutch slipping...
Maybe im missing something, the reason it wont do it 1st run out is because it has had time to cool down...
the clutch was done a month before i got the car its and excedy cushion button clutch also does not explain the error code
dont get me wrong the clutch sliping could be a posibility but normally with clutch slip your revs will go up because the engine cannont transfer power thru the box to the wheels
now when i say dead reving i mean the car keeps reving but the reving slows down and you can feel the power drop off
By dead revving I thought you meant revving but not making power?
Do you mean that it won't rev past 5500 rpm? like it hits wall?
its like when you go past redline the car continues to rev but the power starts to drop off and with this comesa the boost creep its like the timing is being retarded
i tried putting just an\ auto ecu but it wouldn start my car and i dont no why unless there is a neutral switch that has to be bridged but being a factory manual you would think it wouldn have one???
alright i just put a manual ecu in and the problem is still there but its a lot less noticble althought i think it has something to do with the aggresive ness of the timing of the mines ecu does anyone no if the knock sensors can be cleaned or something
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
