Disc Rotor And Hat Dissassembly.
fungoolie
 Share
On the ongoing saga of why my front wheels clatter and click when turning and Nissan HPC in SA saying that is a problem they can't fix and to just to live with it. I'm starting to wonder if its the floating type brake rotors that's the root of the problem... If so why can't we disassemble the "Mclaren" style anti rattle pins securing the rotor to the hat? The manual says it's a non serviceable part and Nissan HPC reiterated that to me saying even they cannot disassemble them. They've cleaned the mating surface between the back of the hat and the hub and that fixed the problem for a week. I suspect that wasn't the actual source of the problem and just playing around with the bits concerned alleviated the problem for a week before it returned. Im starting to suspect that the "anti rattle" springs used to mount the rotor to hat aren't so anti-rattle and this may be where the problem stems from. Seems odd that they don't even recommend that if you disassemble the parts that you reassemble with new pins, springs etc and just re loctite them..... Has anyone pulled their rotors off their hats?
I've replaced r35 rotors a few times (onto stocker hats). I think it's fair to say the clicking noise isnt related. Just IMO. Sounds a bit fanciful to me.
Edited by LSX-438
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
