Car: Nissan Skyline R33 GTS-T s2 , RB25DET
Hey guys I was driving my Skyline r33 gts-t tonight and I noticed that I wasn't really getting the amount of boost I think I should be. From a standstill when I give it some rev's and then launch it gives me the correct amount of boost but when driving I found from 3 to 4th and to 5th the boost was less than usual.
so I changed the boost up two notches on my turbo smart boost controller an noticed minimal difference, although I'm not sure what the notch to psi ratio is.
Then I was finding that in 3rd gear I would accelerate and the turbo would start fluttering and the boost needle would be knock around like crazy then I could ease off and go and it would be fine. The thing is though that this only happens some of the time. I'm still learning so not really up to par with all the lingo. If anyone could help me out it would be nice.
Thanks!
https://www.sau.com.au/forums/topic/317116-turbo-problem/
when you say the bost needle knocks around like crazy does your boost increase or nothing happens? from what your saying my assumption is your hitting a boost spike... and if there is no boost throughout 3rd- 5th i would throw out there you have a boost leak somewhere or your turbo is giving up or has given up on you
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5186286
so ur hearing flutter and ur boost gauge needle is all over the show under acceleration?
that sounds weird. btw flutter is the noise of the air running back through the turbo when u close the throttle it shouldn't be doing it under acceleration
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5186342
a boost gauge needle bouncing up and down and turbo flutter on acceleration sounds just like surging to me, caused by restriction on the compressors inlet. causes of the restriction could be the stock rubber inlet pipe sucking closed if you still have it (its a common problem), or something simple like a dirty air filter. i think you'll find the is more engine load in 3rd than in 1st and 2nd, hence why you only start seeing the problem in 3rd.
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5188996
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
