Car: Nissan Skyline R33 GTS-T s2 , RB25DET
Hey guys I was driving my Skyline r33 gts-t tonight and I noticed that I wasn't really getting the amount of boost I think I should be. From a standstill when I give it some rev's and then launch it gives me the correct amount of boost but when driving I found from 3 to 4th and to 5th the boost was less than usual.
so I changed the boost up two notches on my turbo smart boost controller an noticed minimal difference, although I'm not sure what the notch to psi ratio is.
Then I was finding that in 3rd gear I would accelerate and the turbo would start fluttering and the boost needle would be knock around like crazy then I could ease off and go and it would be fine. The thing is though that this only happens some of the time. I'm still learning so not really up to par with all the lingo. If anyone could help me out it would be nice.
Thanks!
https://www.sau.com.au/forums/topic/317116-turbo-problem/
when you say the bost needle knocks around like crazy does your boost increase or nothing happens? from what your saying my assumption is your hitting a boost spike... and if there is no boost throughout 3rd- 5th i would throw out there you have a boost leak somewhere or your turbo is giving up or has given up on you
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5186286
so ur hearing flutter and ur boost gauge needle is all over the show under acceleration?
that sounds weird. btw flutter is the noise of the air running back through the turbo when u close the throttle it shouldn't be doing it under acceleration
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5186342
a boost gauge needle bouncing up and down and turbo flutter on acceleration sounds just like surging to me, caused by restriction on the compressors inlet. causes of the restriction could be the stock rubber inlet pipe sucking closed if you still have it (its a common problem), or something simple like a dirty air filter. i think you'll find the is more engine load in 3rd than in 1st and 2nd, hence why you only start seeing the problem in 3rd.
https://www.sau.com.au/forums/topic/317116-turbo-problem/#findComment-5188996
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
